17” wheels
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by RTSE, Jan 27, 2021.
  1. RTSE
    RTSE Member
    32
    Apr 11, 2020
    I have a 78 Camaro that I have fitted C5 corvette brakes (13”) and rear disc brakes I now need 17” rims to get it home, I have found American racing Rodder wheels 17 x 7” & 17 x 8” rears, wheels are 0 offset. What I am hoping to do is run a a tall tyre as I am running 3.9 diff gears on a TH350 auto so will be reving hard while cruising. I also looking for that old school look with a tall tyre. What I want to know
    is zero offset the best thing and what is the biggest tyre I can get under the front guards considering I am running 17x 7” wide rims also what is the tallest and widest tyre I can get on a 8” rim
    Thanks
  2. Zspoiler
    Zspoiler Veteran Member
    3,864
    393
    May 6, 2012
    Federal Way, Washington
    I have a 1979 Z-28 with Baer 13" in front and 12" 4 piston caliper brakes . I run a set of 17 x 8 Torque Thrust wheels with 4" front and 5" in back ,And with a Super T-10 4 speed with 3:42 gears .It runs around 2600 rpm at sixty , Im quite not sure on my tire size .But is around a 225/17/50in front and as 295/17/50s in back, And with a 377 cubic inch supercharged small block .I tried to get as much tire as I could. image6.jpg
  3. G72Zed
    G72Zed Veteran Member
    2,352
    1,029
    Sep 8, 2015
    Just make sure the center/spoke rim design clears your calipers, this is regardless of offset. Most brake companies have a scaled diagram that can be printed and cut out, or send the pdf file to the rim company to make sure they fit. nothing worse than buying rims only to find out they hit the calipers and need to run spacers that overstress the studs (not good) and push the wheel out and bugger up your fitment. JMO
  4. Zee
    Zee Veteran Member
    1,083
    8
    Feb 6, 2000
    Montgomery IL
    My 17" American Racing wheels did not fit the C5 template I cut out. Too little caliper to barrel clearance as there was a "step" in the barrel of the wheel. That is how I ended up with C4HD brakes on mine.
  5. 8pack
    2,743
    193
    Aug 29, 2007
    Western, MA
    On a Z28 Stock wheels are 15x7 with 4.5” backspace. 225/70/15 is 27.4” tall.
    If you work backwards to find a 17” tire that is close to the same diameter a 235/55/17 tire is 27.2” which gets you close to stock diameter.
    Those should fit your 17x7 and 17x8” rims fine and if you stay with sto ck backspacing you should be good. However, NO GUARANTEES! Everyone’s car is different. If the front end is lowered that tire may be too tall.....
    I currently run 235/60/15 which is 26.1” on a lowered car with plenty of clearance.
  6. RTSE
    RTSE Member
    32
    Apr 11, 2020
    Thanks, will look out for tires
  7. Zee
    Zee Veteran Member
    1,083
    8
    Feb 6, 2000
    Montgomery IL
    255/50-17 is approx. 27" and fits on a 4.5" backspace rim on a Firebird. It is a tight fit on the front. Not sure if it would fit the front of a Camaro
  8. BonzoHansen
    20,567
    1,705
    Jun 1, 2005
    Scott from Hamilton, NJ
    That tall and wide likely won't fit up front of its lowered at all
