1. foxracer6565
    foxracer6565 Member
    41
    May 1, 2010
    montrose, pa
    i have a 72 camaro just bought 17x8 4.5 backspace and 17x9 5. beckspace
    I want to put 235/45/17 front and rear 255/45/17. will that work for me?:bowtie:
  2. nobreaks254
    nobreaks254 Veteran Member
    499
    9
    Jul 14, 2007
    aberdeen, SD
    with those size rims most go with 245/45/17 front and 275/40/17 rear. But those sizes should work but would be alittle narrow for those wheels.
  3. Lowend
    15,284
    612
    Mar 25, 1999
    San Jose, CA, USA
    I would go 245/40/17 in the front, and 275/40/17 out back
  4. foxracer6565
    foxracer6565 Member
    41
    May 1, 2010
    montrose, pa
    but it looks like it mite be to tight. everything is stock on the car i would love to go 275/40/17 but i dont want to rub
  5. foxracer6565
    foxracer6565 Member
    41
    May 1, 2010
    montrose, pa
    thanks for your help too.
  6. Kasey74
    Kasey74 Veteran Member Lifetime Gold Member
    1,143
    Oct 7, 2002
    Calgary, Alberta, Canada
    i went with the 245/40/17 in the front, and 275/40/17...dont rub at all, but wish i would have went with a 245/45/17, and 275/45/17, just to get a bit more sidewall. the 40's are cool, but look a little small. I've seen guys run 285's out back, but the wheel offset better be perfect (not sure what offset on stock rearend, since i put in a '80 T/A rear disc rearend...just measured what i needed) , or they mite rub
  7. 5spd540
    12,388
    16
    Sep 19, 2009
    Guyton, GA
    I like the 45 better than the 40 for the sidewall reason also
  8. Aceshigh
    26,757
    Apr 9, 2001
    Boondocks
    I have
    245/45/17 with 4.5" backspacing on 17x8" front's
    275/40/17 with 5.5" (IIRC) backspacing on 17x9.5" rears
    So I think it will be fine.
    I'd suggest getting the biggest tires ya can though.
    I have zero rubbing issues with the Hotchkis TVS and before it I had none either.
    It's all about the proper backspacing.
