17x8 245/45/17 front tire rub
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by Blu-By-U 79Z, Oct 4, 2014.
  1. Blu-By-U 79Z
    Blu-By-U 79Z Veteran Member Lifetime Gold Member
    5,566
    24
    Feb 11, 2009
    Kentucky
    17x8 4.5 bs 245/45/17 front tire rub
    So today was the first day I got to drive the car with the new tires on it. Everything went pretty good but hitting decent bumps caused the front tires to rub. Its right where the tub of the inner wheel well turns outward to bolt to the fender. Its about a 1/4 inch from the "L" of the inner fender. Any ideas on how to fix this issue? Ive heard about adjusting camber. I still need to get the car aligned. I am just wanting to get some ideas for a fix. Thanks
  2. Hoppie
    Hoppie Veteran Member Lifetime Gold Member
    108
    Sep 11, 2010
    Seattle,WA
    Negative camber will help. What backspacing are you running on your wheels? I had rub with 4.5 with an 8 inch wheel. Changed to 4.75 and have had zero issues over some pretty big bumps. It was frustrating. But get an alignment for now and it really should help.
  3. KEVS79
    KEVS79 Veteran Member
    2,465
    Mar 3, 2008
    GLADSTONE, MO
    That stinks!! So is it the tread part of the tire that is hitting the inner fender?
  4. Blu-By-U 79Z
    5,566
    24
    Feb 11, 2009
    Kentucky
    Just on the edge of the tread. They are 4.5 bs. They didn't offer 4.75. I looked. But many people run this combo without issue.
  5. KEVS79
    2,465
    Mar 3, 2008
    GLADSTONE, MO
    Might try the alignment first and get the camber on the negative side then might have to bend the inner fender to make it clear. Try searching alignment specs. There are recommendations that are different than the factory settings. I think camber is like 1-1.5 negative if I remember right.
  6. doublec
    doublec Veteran Member
    1,977
    Dec 18, 2011
    Harrisburg, Pa
    I run a 4" back space on the front with my 17's and have no issues.
  7. my24ktrat
    my24ktrat Veteran Member
    1,233
    Jul 5, 2007
    Roch., NY
    ...Also at home depot they sell round hex head stainless bolts to replace the factory ones in fenderwell in case of contact with the tire,every little bit helps,eliminating edges, just my.02, DC
  8. Blu-By-U 79Z
    5,566
    24
    Feb 11, 2009
    Kentucky
    Thanks guys. I think the first step is alignment. Then some inner fender loving lol. The car handled great though lol
  9. Blu-By-U 79Z
    5,566
    24
    Feb 11, 2009
    Kentucky
  10. sandiego74
    sandiego74 Veteran Member Lifetime Gold Member
    1,160
    77
    Feb 23, 2009
    San Diego, CA
    Had the very same problem, even with some negative camber in the alignment. I pounded the areas where it rubbed with a sledge and it the rubbing ceased unless I hit a bump too hard.
