1970-1973 Hood Latch I.D.
Discussion in '1970 - 1973 Specific' started by Plater Tom, Aug 10, 2021.
  1. Plater Tom
    Plater Tom Veteran Member
    1,494
    82
    Feb 2, 2003
    Mt Pleasant, Pa. USA
    Does the end of the pull part of the latch look correct, or has it been damaged? Tom
  2. BillyDean7173
    BillyDean7173 Psychopathy Red
    3,043
    1,106
    May 21, 2014
    Hutto, TX
    Looks fine to me. The latch on my 71 doesn't have such an extreme dip in the middle like yours, but the end looks the same. I can't compare it to my 73Z since she's in the shop getting her 500 mile checkup.
  3. Plater Tom
    1,494
    82
    Feb 2, 2003
    Thank You
    BillyDean7173 likes this.
  4. CamaroDoc
    CamaroDoc Veteran Member
    2,251
    266
    Sep 13, 2003
    Skiatook, Okla. 74070
    Should look like this..
  5. Bills69
    Bills69 Veteran Member
    295
    34
    May 28, 2018
    when you open your hood does it release all the way past the safety latch or does it catch ?
  6. CamaroDoc
    2,251
    266
    Sep 13, 2003
    It will catch on the safety latch hook by design. You have to hold the handle until you lift the hood clear of the safety catch.
  7. Bills69
    295
    34
    May 28, 2018
    so it should catch at original release , it goes right by on initial release but does catch if push down on hood by hand
    so alignment is correct
    is it correct to have the hood sitting on side posts for alignment of the fenders and the spring post adjusted to just pop up to open hood
    thanks
