1970-73 camaro part.
Discussion in 'Swap Meet Section' started by john Gialanella, Aug 19, 2014.
  1. badazz81z28
    20,971
    1,472
    Alabama
    Pm
    Sent
  2. elev8rguy
    elev8rguy New Member
    Oct 10, 2008
    yakima, wa.
    Hey John,
    Would you happen to still have the window sweeps and the light switch? Let me know please.
    Thank you.
  3. weircc
    weircc New Member
    23
    Jan 9, 2010
    richmond mo
    Driver side pillar trim? 71?
  4. Bigblockscott
    Bigblockscott Member
    38
    Feb 16, 2017
    Hey John, I am looking for an ignition switch housing for a 1970 non tilt steering column, mine got bumped off the work bench today and broke.
  5. Bigblockscott
    38
    Feb 16, 2017
    John, It's the aluminum housing that the actual ignition key switch mounts into. I appreciate you looking. I believe they are the same for just about all chevy cars of that era. I'm hoping the junk yard has something usable for me. I appreciate you looking though, Thanks
    Scott
  6. LB70
    LB70 Member
    70
    Jul 2, 2011
    ft walton beach fl
    Hey John,
    Looking for a wiper switch for non hidden wipers on a 1970. Thanks
  7. LB70
    LB70 Member
    70
    Jul 2, 2011
    ft walton beach fl
    Ok, thanks John
  8. RacnJasn93
    RacnJasn93 New Member
    Nov 18, 2020
    Hey John,
    Would you happen to have a fuse block for a 70-73? Maybe a dash harness with bad wiring? I Just need the plastic block. Thank you!
  9. RacnJasn93
    Nov 18, 2020
    Thanks for your help John!
  10. H&S-Builds
    H&S-Builds New Member
    16
    Jan 21, 2021
    Fitzgerald. GA
    I just took out a complete harness from a '72 Standard Camaro (got a 402 in it now) and installed a new autowire complete system.
    Shoot me a message.
    Also looking for the roof rail vertical (short) weatherstripping channels for left and right hand side for same '72 model if anyone has a good deal on some.
    I did find them here (https://www.camarocentral.com/1970_1981_Camaro_Roof_Rail_Weatherstrip_Channel_p/wea-167cr.htm) but $75 is a little much for those little pieces.
