1970-73 Rear Window Trim?
Discussion in 'Body Restoration' started by Patrick Baker, Jul 15, 2021.
  1. Patrick Baker
    Patrick Baker 71RS
    30
    Apr 25, 2021
    How does the after market rear window trim fit?
  2. badazz81z28
    20,947
    1,470
    Alabama
    It fits great! It’s not exactly like OE however. AA00B919-F7EE-4DE5-A72F-6E21435CDC8C.jpeg
    Patrick Baker and MChamp like this.
  3. Patrick Baker
    Patrick Baker 71RS
    30
    Apr 25, 2021
    Really doesn't look that much different. Looks a lot better than I thought it would. Thanks for the picture.
  4. badazz81z28
    20,947
    1,470
    Alabama
    Yeah, you’re really not gonna know unless you compare side by side or just know what you’re looking at.
    Patrick Baker likes this.
  5. 71Z28454
    71Z28454 New Member
    28
    Jun 1, 2007
    Chino Hills, CA
    Badazz, question for you....reading other posts on NOS Trim, was it difficult to install? Any tricks or recommendations? Read that they are very soft and bend when snapping over the retaining clips.
  6. wnmech
    wnmech Veteran Member
    1,322
    278
    Jul 20, 2014
    grand prairie tx.
    Myself I had a few issues installing my aftermarket trim actually I ended up buying a second set of trim because I was used to old school way by hitting the trim with my fist over the clips. The way I finally got my trim snapped down was by buying the trim removal tool and inserting it on to the clip and then pushing the trim down and it did lock good. The trim tool is not very expensive.
  7. badazz81z28
    20,947
    1,470
    Alabama
    It’s very dependent on what clips you use. Some clips, especially the “correct” clips are very tough. You need the removal tool to pull the clip to engage the trim. Some clips are soft and flexible enough to just push the trim down. Def don’t smack it, palm it, you will risk damaging the trim OE or not.
  8. Patrick Baker
    Patrick Baker 71RS
    30
    Apr 25, 2021
    Got lucky and found a oem set on Ebay last week. Really nice for 50 years old. Shines like new, and very few scratches. I don't think I did to bad $265. + Shipping.
    Zstar likes this.
  9. badazz81z28
    20,947
    1,470
    Alabama
    Sure it’s OE? I suspect it’s not by looking at those corner pieces.
  10. Patrick Baker
    Patrick Baker 71RS
    30
    Apr 25, 2021
    It looked weathered on the underside with grit ect. Also had some black vibration type pieces on the underside.
