1970 Alternator detail.
Discussion in 'Original Drivetrain Topic' started by 67johnny, Apr 8, 2021 at 1:49 AM.
  1. 67johnny
    67johnny Veteran Member
    264
    12
    Apr 14, 2016
    vancouver
    Hey all...
    I am looking for info on the alternator fan.
    I have the correct nut,wavy washer and pulley.
    I am unsure on what is correct fan wise and if someone can let me know how many blades, color and any special marks etc. that would be much appreciated.
    Thanks.
  2. McCune
    McCune Veteran Member
    1,293
    302
    Aug 22, 2015
    st.george utah
    11 blade, fat blade, no hook.
  3. COPO
    20,342
    2,152
  4. 67johnny
    264
    12
    Apr 14, 2016
    vancouver
    No Hook?
  5. Twisted_Metal
    29,043
    2,109
    There is an 11 blade alternator fan design used on other GM cars which has a "shark fin" on the ends of the blades. (Not correct)
    And another design which has a hook on the "fat" blade. (Not correct)
    The correct fan is the one in COPOs pic.
    It has no "hook" or "shark fins" on any of the blades.
  6. 67johnny
    264
    12
    Apr 14, 2016
    vancouver
    Much appreciated!
    I will look at the three I have and compare.
    Thanks All:bowtie:
  7. bkmont
    bkmont Veteran Member
    1,196
    112
    Nov 14, 2010
    Pensacola, Florida
    No hooks on my 837.
  8. 67johnny
    264
    12
    Apr 14, 2016
    vancouver
    There seems to be a lot of fan choices and designs over the years.
    The one on the bottom in the pic appears to be correct.
    I am curious to know how many designs they did have available... what was the purpose of the small V notches, the one wider blade and other engineering trivia as it makes for a good read!
    The Devil is in the details they say.
  9. 70lt1z28
    4,166
    950
    Oct 3, 1999
    Beavercreek, Ohio, USA
    Just a guess on my part, but I have heard that they were experimenting with the blade designs due to noise. The fan spins pretty fast and can create NVH (industry parlance for noise, vibration and harshness) issues.
    Some of the "fins" I think are caused by tooling issues. The small tabs on the tips of the blades are remnants from the progressive dies used to stamp the part out of a sheet of metal. The tabs I think are used to carry the part through the die as it get formed. If the die progression (a setting in the press) changes from run-to-run it can effect the size of the tab as it is cut out at the last station in the tool where the fan is punched out.
    l16pilot likes this.
  10. 67johnny
    264
    12
    Apr 14, 2016
    vancouver
    I noticed that there are a lot of different stamps on these fans like the ICR or KR stamp visible in the lower pic.
    They must have had a bunch of OEM shops on the go.
