1970 Camaro Rear Shock Replacement
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by Robert M Mrozek, Mar 14, 2020.
  1. Robert M Mrozek
    Robert M Mrozek Veteran Member
    124
    20
    Oct 4, 2016
    I am trying to purchase replacement REAR shocks for my 1970 Camaro. The current shocks (see attached pictures) have an approx 2 in extension. I am not sure if this extension is normal or something the prior owner did. Without the extension the shock is too short. I am trying to select rear shocks replacements that do not require this extension. Any advice on why this extension is required? Any idea if a longer shock, like a 22.5 in, is the best solution? Thanks.
  2. Gary S
    24,011
    1,555
    With factory suspension, any factory replacement shock will fit without any extensions. Extensions are a "patch" for modified suspensions.
  3. biker
    biker Veteran Member
    3,803
    1,797
    Dec 7, 2014
    Someone cobbled that on there to make a short shock work, or to compensate for a lifted rear spring. If you have stock ride height, or close, any stock height shock will work.
    ronzz572 likes this.
  4. 70lt1z28
    4,406
    1,044
    Oct 3, 1999
    Beavercreek, Ohio, USA
    Leaf spring shackles to raise the rear end usually required those type of kludges. I remember a guy in high school had to add two of those in-line on a Nova
  5. mjoc
    mjoc Veteran Member
    3,534
    Apr 29, 2003
    Sherman Oaks, Ca
    just measure and you can order shocks that will fit Call Koni or Bilstien or QA1
