1970 Camaro Rear Wheel to Inner Fender Clearance
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by Robert M Mrozek, Aug 10, 2021.
  1. Robert M Mrozek
    Robert M Mrozek Veteran Member
    125
    21
    Oct 4, 2016
    1970 Camaro with Rear: P275/40R18 Nitto Nt555 G2 Summer Ultra High Performance Tire with recently installed UMI 2in lowering kit. My driver's side rear tire is slightly rubbing the inner fender lip. At the fender lip seam where the outer panel and inner fender meet. I think I need about 3/16 in clearance to reduce the rubbing. I thought about rolling the fender but the outer fender has bondo in it so I am concerned about cracking the bondo and making the situation worse. Perhaps slowly removing a segment of that inner lip with a fine metal file? Or perhaps some other solution other than getting new wheels and tires. Any suggestions? Thanks!
  2. badazz81z28
    21,140
    1,509
    Alabama
    Your wheel tire combo isn’t ideal. You roll the lip to clear the lip, not the outer fender well. You can always cut it a weld a pocket for it to clear.
  3. Robert M Mrozek
    125
    21
    Oct 4, 2016
    I ended up removing about 1/4 in of inner fender lip with a cutting wheel and then grinding it smooth....problem solved...by a hair though. It is close.
  4. Zstar
    Zstar Veteran Member
    2,702
    944
    Mar 23, 2014
    Ocala, Florida
    Really nice wheels!
  5. mrfleet12
    mrfleet12 Veteran Member
    988
    654
    Aug 8, 2014
    West of Chicago IL
    Any full pics of your car with those wheels?
    I ran those on my 73 but with black centers.
    Been considering them for my 70.
  6. streak
    streak Member
    37
    11
    Apr 27, 2021
    Looks like you have 2 separate issues. If it's rubbing where your arrow is pointing then it would help but a bad idea when there's bondo. Cut and repaint. Where you have a visually evident rub mark on the inner there are only 3 fixes. You either buy a different offset wheel, buy a narrower tire, or as mentioned try to weld a clearance pocket in the inner fender.
  7. 73standard
    73standard Veteran Member
    194
    Oct 25, 2001
    Oregon
    Which wheels and offset are those? I'm trying to pick out new wheels now and those roughly look like something I was seriously considering.
