1970 Camaro Restofy
Discussion in 'Project Progress' started by giggity, Apr 6, 2016.
  1. giggity
    giggity Veteran Member
    1,318
    266
    Mar 18, 2013
    Pearland, texas
    seat bolts came in, and was able to bolt in passenger side seat and get a better idea about how the center console will fit. Its a little tight on the seats, but not bad. I need to make a bracket to mount the center console. Id like to be able to lean on it , and need to fit the shifter boot. Not getting too involved in this yet, Im mostly getting the new seats out of the way, because wife wont let me bring the seats in the house. need to get some bags to cover them while im doing paint and body work, but I have a feeling ill be removing, I dont want to mess them up.
    huff_diesel, dcozzi and BillyDean7173 like this.
  2. dave@ztech
    4,414
    981
    Mar 27, 2016
    NY
    The console, looks like it will be high enough to rest/lean on , damn those seats look great in there!!
    giggity likes this.
  3. giggity
    1,318
    266
    Mar 18, 2013
    Pearland, texas
    thanks! I love that it has drink holders and USB, which I will wire up. Im probably going to start working on covering the rear seat soon, but not too worried about it, since I can drive around without rear seats for a while.
    dave@ztech likes this.
  4. giggity
    1,318
    266
    Mar 18, 2013
    Pearland, texas
    had to modify my stool to make it lower, so I can sit lower in relation to car on cribs. Got this stool from a inventory sale from a local university, picked it up for 5 bucks!
    back to body work and all-metal
    My previous attempt to apply was a fail, I have sanded off anything that was gummy, and reapplied to areas.
    I think im getting the hand of this stuff, its applying much better. My technique was to put a golf ball size amount on my plastic board, and take the hardener with me to the spot ill be repairing, then once I have myself situated, I add hardener, mix thoroughly , and then apply. The key to this stuff is apply early and work the spot quick, it sets really fast. I've played around with hardener, if I put too little, it doesnt harden enough or quick enough. So for me adding the correct amount of hardener, and just apply it quickly works best.
  5. dave@ztech
    4,414
    981
    Mar 27, 2016
    NY
    I’m sure the heat and humidity also plays into your working time
  6. SPG
    SPG Bumblebee Builder
    796
    236
    Sep 1, 2018
    Sacramento
    those things have stalled all my progress, more so the heat. Can't paint when it's 110 and it dries too quick. And it's still too hot in the mornings!
  7. giggity
    1,318
    266
    Mar 18, 2013
    Pearland, texas
    I could see no humidity being an issue to, but at least you dont have the flash rusting issue with the humidity. Ill work a panel, and within minutes can see flash rust. its not uncommon for me to have to re-sand a panel before applying epoxy.
  8. giggity
    1,318
    266
    Mar 18, 2013
    Pearland, texas
    too humid out this weekend to run compressor for sanding, so I did some odds and ends.
    Took rear cover off, put gasket in and buttoned up. Filled with gear lube. I had planned to run synthetic, but not until the gears are properly broke it. I read that it needs standard gear oil for the friction. Once broke in later Ill change to synthetic , one nice thing about the true-trac, no friction modifiers needed.
    went ahead and gravity bled the rear brakes, I probably need to pressure bleed them at some point, but I got most of the air out i think.
    finished plumbing and wiring tanks inc tanc, and in tank pump.
    installed tank
    for 21.5 gallon tank its not very visible from rear. I did have to readjust the filler tube once the tank was in, pushed it down.
  9. thesalboy
    thesalboy Veteran Member
    466
    199
    Mar 25, 2017
    Los Angeles, CA
    Same here.
    Are you not running your fuel pump and sender wire via the hole above the filler tube?
  10. 75Maro
    75Maro Veteran Member
    554
    71
    Mar 31, 2008
    Dallas,Tx
    Speaking from experience, those anti rattle strips above the gas tank will be your best friend.....
    I tried it without, about rattled my teeth out
    giggity likes this.
