1970 Camaro Restofy
Discussion in 'Project Progress' started by giggity, Apr 6, 2016.
  1. thesalboy
    thesalboy Veteran Member
    518
    242
    Mar 25, 2017
    Los Angeles, CA
    Send it back. Here's a large pic of mine, which I picked up from their Ventura, CA location, like two or so years ago. Yours could be "old stock" - they have done several versions over the years - easiest to dump them on Internet buyers. From what I've read, they will make it right.
    giggity likes this.
  2. John Wright
    15,194
    392
    Aug 9, 2002
    Rustburg, Va
    I'm assuming that mine had been replaced when I got the car, but there is a huge gap between the door and the dash on the driver's side. It's large enough that I can fit my hand in there. How close should these fit at the door near the A pillar?
  3. thesalboy
    518
    242
    Mar 25, 2017
    Los Angeles, CA
    I went through my pics but don't have one that shows both sides that I know accurately reflect both gaps (none of both sides at the same time or taken at the same time). I know for sure isn't a tight fit and vaguely recall being able to put my hand in with it pushed to one side. The A-pillar trim covers it where it's most visible. This is the best pic I have of the gap once everything is installed - this is with the dash centered so gaps are even on both sides, which seemed better than huge on one side.
    John Wright and giggity like this.
  4. John Wright
    15,194
    392
    Aug 9, 2002
    Rustburg, Va
    Thanks Sal...
  5. giggity
    giggity Veteran Member
    1,554
    386
    Mar 18, 2013
    Pearland, texas
    Had good weather yesterday, so took off half a day to epoxy. I mixed up 2 quarts of epoxy, ended up being short on paint.
    Got a little bit of trash in it, but again...my environment isnt sterile. Plus I have to sand it anyways for high build.
    you can see where I ran out on this side. I ordered another gallon.
  6. linenoise
    linenoise Veteran Member Lifetime Gold Member
    240
    39
    Apr 17, 2000
    CO
    BLACK?? so nice looking. Impossible to keep perfect. Your brave man. I had a C6 that was black. Never again.
    giggity likes this.
  7. giggity
    1,554
    386
    Mar 18, 2013
    Pearland, texas
    Yup, best looking color, but the most maintenance and trouble. I own 3 black vehicles, so well aware of the issues.
  8. giggity
    1,554
    386
    Mar 18, 2013
    Pearland, texas
    did some really lite corrections on garbage in the last coat. and scuffed the underside of the trunk lid and spoiler. Im in the 7 day window of the epoxy cure time, so didnt need to scuff the entire panels.
  9. giggity
    1,554
    386
    Mar 18, 2013
    Pearland, texas
    Got my gallon of epoxy in on Friday, Saturday was able to heat garage to 70 degrees, and spray the panels.
  10. giggity
    1,554
    386
    Mar 18, 2013
    Pearland, texas
    scuffed, wiped and painted engine side of fenders, under side of trunk lid, trunk jam, and upper trunk piece(whatever that thing is called)
    Everything sprayed great until my third coat, and im not sure what happened here...almost like it was too dry.
    I figure I can wet sand this with 3 coats, but still weird, if its technique, I need to work that crap out before I get to spraying the entire car.
    SPG likes this.
