1970 Camaro Restofy
Discussion in 'Project Progress' started by giggity, Apr 6, 2016.
  1. giggity
    giggity Veteran Member
    1,562
    386
    Mar 18, 2013
    Pearland, texas
    Put hood on, I just realized the hood doesnt fit with the current air cleaner setup, anyone running cowl induction hood, and what air cleaner you using? Im considering making it a functional cowl induction hood, meaning adding the engine separator thingy.
  2. rotinrob
    rotinrob Veteran Member
    109
    33
    Oct 2, 2018
    I have the cowl hood. They are intended to be made functional (you can buy kits to do this) but mine just has the air cleaner stuck into the hole. I'm using a standard aftermarket air cleaner at the moment. I intend to put the original hood back on it as soon as I can reskin the original as someone before me cut a big clearance hole. I now have the stock low rise and I want to showcase the original L78 dual snorkel set up plus keep it as close to original as possible.
    rgs
    giggity likes this.
  3. dcozzi
    dcozzi Veteran Member
    4,114
    1,088
    May 1, 2002
    Phoenix, AZ
    Look into a "drop base" air cleaner. I do not guarantee it will fit around the FiTech though. It may be a different shape than a Holley carb.
    giggity likes this.
  4. mrfleet12
    mrfleet12 Veteran Member
    763
    388
    Aug 8, 2014
    West of Chicago IL
    Where is it hitting, front, back?
    My buddies 68 hit the front I think, he bought an offset base which centered filter it in the cowl hole and it worked perfectly.
    giggity likes this.
  5. giggity
    1,562
    386
    Mar 18, 2013
    Pearland, texas
    Im going to try messing with the adjustment of the hood a little and see if I can center the hood better. Ill take some better pics.
    mrfleet12 likes this.
  6. giggity
    1,562
    386
    Mar 18, 2013
    Pearland, texas
    yea, I can easily go down 2 inches. I never realized there were so many different options on air cleaners, Ill have to do some digging on what works.
  7. giggity
    1,562
    386
    Mar 18, 2013
    Pearland, texas
    Removed the air cleaner and trying to align hood. Its not terrible, but I have a feeling I will be spending a lot of time trying to get this lined up correctly. Im still looking for someone locally who could simply just line everything up for me. I pride myself on trying to do things myself, but I would gladly pay someone at this point to get all my panels straight, and gapped correctly.
  8. linenoise
    linenoise Veteran Member Lifetime Gold Member
    241
    39
    Apr 17, 2000
    CO
    totally agree. And looking all this time at your posts your better at body work than I am so if you think you are going to need help betting I will for sure. was kinda counting on adjusting till right.
    giggity likes this.
  9. hwprouty
    hwprouty Member
    40
    24
    Jun 14, 2005
    Granite Falls, Washington
    I just read through your thread, nice job!!
    Lotsa work!!
    giggity likes this.
  10. rotinrob
    109
    33
    Oct 2, 2018
    My cowl hood has a terribly inconsistent gap along the top of the fender. It starts out nice and progressively gets wider towards the doors. The GM fenders really can't go in any further to help with the gap. I do need to reset the one door a bit for getter clearance of the edge guard but I doubt if that will help much. Being an aftermarket hood a lot of the time we either need to accept some poor fit or do some modification to get a better fit. I will also put the original hood back on to recheck the alignment with that hood as I intend to go back to the flat hood when I have time to reskin it as it has a big hole cut into it.
    rotin
    giggity likes this.
