1970 Camaro Restofy
roadrace2
1,860
Earth......?
I've had the same issue with low miles and rust inside my MSD distributor. A member here years ago told me to drill 2 very small vent holes in the cap near the base to allow the moisture to vent out. I did this and it seems to work.
giggity
1,682
Pearland, texas
Googled it, apparently a really common issue. I think you 100% correct, I need to drill a hole to let it vent. Its weird, because the cap has a vent.
giggity
1,682
Pearland, texas
WHUT??? 238 days for legendary door panels????
giggity
1,682
Pearland, texas
putting things back together, and had a thought about running wires under headers. # 4 wasnt having it. probably have to change sparkplugs to get this to work.
giggity
1,682
Pearland, texas
funny the things you noticed AFTER the fact...
Noticed the spacer isn't matched to the intake. And the intake needed to be deburred on the plenum,next time i take off intake ill fix it. I dont think the spacer will cause much of an issue, but something to think about later.
giggity
1,682
Pearland, texas
was able to get some work done over the weekend.
I contacted Fitech, and got a firmware update, and reconfigured my setup seems to be idling better.
