giggity
I located the seatbelt holes and cut a small hole for the bolts, in process one of the holes the threads were boogered up, so had to chase the threads. probably messed up the bolt. Im not running rear seat belts, so should be ok. No one is going to sit back there anyways.
I placed seats in, the seat bolts i used are coming up through bottom to make it easier to transfer seats, Ill probably go back later and replace them with downward facing bolts.
Carpet is still very lumpy and needs adjustment.
