1970 Camaro roller
Discussion in 'Camaros for Sale' started by Redlines, Nov 4, 2019.
  1. Redlines
    Redlines Member
    97
    Dec 18, 2008
    IL
    $9950.
    1970 Camaro. Selling as a roller however does have 5.3 LS short block. Was a driver but have been parting out due to leaving car hobby.
    Purchased 2003 with odometer exempt title from dealership, I have put my own 5k miles on it since. Block has around 35K.
    Does have a 5.3 LS Vortec short block, iron block, flat tops, GM ASA camshaft and LS2 roller chain assembly. 24x timing, newly installed F-body oil pan.
    No rust thru on body. Its been garage kept for 16 years so that has gone a long way to keep corrosion off car. Panels line up good for a 70. Has some S-10 and space saver wheels to roll on. Paint is good for driver quality. Working lights with Led rears. Body has all lenses and lights. No bumper's. Carbon fiber L88 cowl induction hood with functional heat extraction with real hood locks. Hood clearance allows for tall intakes or truck accessory swaps with top mounted alternators etc. Standard front end nose and grill. Z28 front and rear spoilers. Glass was new right before I bought it along with all seals. Carpet is good. New rebuilt tilt column with billet steering adapter. Window crank mechs work. Door trim and headliner are not stock but we're put in right before I bought it.
    Manual pedals. No seats or console. Dash is there but no lower and it's associated parts gone too. Harness is loose and needs to be redone, however if patient you could probably hook the harness up as is due to most wires labeled. No engine harness. Lots of under hood parts are gone. New gas tank for FI, Tanks Inc TM42A-T & their intank 255lb fuel pump + sender. Fuel lines still installed too. Rear disk brakes are complete and front has disk rotors but no calipers. Powertrax rear end diff in OEM 10 bolt.
    BMR front lower arms, subframe connectors. Hotchkis springs front & back. Street cage bolted in
    hubedobeedo likes this.
  2. Redlines
    Redlines Member
    97
    Dec 18, 2008
    IL
    more
  3. grzewnicki
    3,463
    187
    Dec 9, 2009
    Gordon from Jacksonville Fl
    I didn't know this was a hobby I could quit at any time...I'm hooked, more like a disease, Good luck with the sale!
    70-camaro likes this.
  4. Redlines
    Redlines Member
    97
    Dec 18, 2008
    IL
    More
  5. stafs05
    428
    26
    Dec 26, 2007
    chicago,IL
    I have the same disease. It started at 13 and I still have it. Good luck with the sale
  6. 70pete
    70pete Veteran Member
    108
    15
    Aug 19, 2014
    martinsville, nj
    Hey Redline,
    What brand hood is that? Looks awesome and seems to fit good
  7. Redlines
    Redlines Member
    97
    Dec 18, 2008
    IL
    Don't know the brand, bought nearly a decade ago. Was made in Japan, after I put in custom order and shipped to me. Fits better than any others I have seen. All I had to do was just install it, needed zero mods to shape or edges
  8. Redlines
    Redlines Member
    97
    Dec 18, 2008
    IL
    have been requested to post outdoor pics of car if possible. So here are a few when it was fully assembled, obviously as mentioned wheels, front brakes, bumpers and seats seen in pics are gone
  9. Redlines
    Redlines Member
    97
    Dec 18, 2008
    IL
    Sold
