1970 Camaro seat track rollers
Discussion in 'Troubleshooting & Diagnosis' started by Jcox90, Feb 2, 2019.
  1. COPO
    19,448
    1,558
    What about using a sealed mini bearing as a roller? Or weld a stack of washers together.
    FlaJunkie likes this.
  2. 70lt1z28
    3,902
    857
    Oct 3, 1999
    Beavercreek, Ohio, USA
    A true craftsman!
  3. Jcox90
    Jcox90 New Member
    17
    Jan 6, 2019
    Thank you wish I would’ve thought of that before I just ordered two new seat tracks lol. Thank you
  4. Taximan
    Taximan New Member
    Nov 3, 2018
    never crossed my mind to use an actual bearing. im lucky i still have all my rollers, but unfortunately i only have 1 plastic bushing. i messaged 70lt1z28 and hoping to get 2 sets made. im building 2 cars and i need 2 sets.... hopefully i can bribe him into it .. nice job on the bearings idea .. what was the bearing number you used... i may switch over if mine dont slide as smooth as i want
  5. stafs05
    440
    29
    Dec 26, 2007
    chicago,IL
    I could use some as well. If he starts to make them Im in.
  6. giggity
    giggity Veteran Member
    1,311
    254
    Mar 18, 2013
    Pearland, texas
    I need some too. Im getting to the point of rebuilding my seats. if I cant find the right parts, ill sure be engineering something to get slides operational.
  7. DCL70
    DCL70 Veteran Member
    1,450
    26
    May 5, 2007
    Southern N.H.
    The seat track bearing assemblies shown in the 3 photos below are from a set of 1993-2002 Camaro seat tracks that was not salvageable because the "feet" were rusted so bad. There were 4 of them but I needed only one for my 1970 driver's seat tracks.
    Each 1970 track uses 2 bearing assemblies:
    One bearing assembly has 4 balls plus a 0.80" diameter wheel (0.51"+/- thick) with a 0.48" diameter hole on one side (not pictured).
    The other bearing assembly has 2 balls plus a 0.80" diameter wheel (0.51"+/- thick) with a 0.33"+/- square hole (center brg. asm. in photos).
    Each 1993 Camaro seat track has one bearing assembly with the 2 balls and wheel with 0.33"+/- square hole (same brg. asm. as 1970).
    The other 1993 bearing has a 0.80" diameter very tight spring (0.55"+/- thick). These are the 2 end bearing assemblies in the photos.
    The stamped steel frames on these bearing assemblies are the SAME SIZE (1.31" long, 1.43" long at tabs by 1.42" wide). The 1993 bearing assemblies can be used on 1970 seat tracks as shown in photo #1. The 0.80" diameter spring works just like the 0.80" diameter wheel. I call it a 2nd design.
    If you need seat track bearing assemblies just find a rusted out set of similar GM seat tracks. I drilled out the 2 dimples on the 1993 seat track to make life easier.
    70lt1z28 likes this.
  8. giggity
    1,311
    254
    Mar 18, 2013
    Pearland, texas
    thanks !!!!
  9. FlaJunkie
    6,356
    238
    Mar 24, 2001
    Rockledge, Florida
    They do look identical. As I understand you, the roller bearing in the 1970 track is identical to the 1993 assembly?
