1970 Camaro with UMI Stage 2.5 Handling Kit 70-81 GM F-Body P/N 236-FBF025-R
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by Robert M Mrozek, Jul 24, 2021.
  1. Robert M Mrozek
    Robert M Mrozek Veteran Member
    124
    20
    Oct 4, 2016
    Posting results and pics of a recent install of UMI Stage 2.5 suspension kit and Wilwood disc brake upgrade on my 1970 Camaro. Work was done by The Hot Rod Shop in Troy, MI. Original handling and braking was fine but this is a serious improvement. Viking adjustable shocks are a nice touch and I have adjusted them twice and quite a difference from comfortable street setting to rock hard race setting. IMG_6259.jpg umi1.jpg umi2.jpg umi3.jpg umi4.jpg
  2. ULTM8Z
    ULTM8Z Veteran Member
    10,112
    913
    May 19, 2000
    Los Angeles
    Wow, gorgeous car!
    Robert M Mrozek likes this.
  3. Oldskool62
    Oldskool62 Veteran Member
    193
    76
    Sep 29, 2017
    Great looking car.
  4. ErikNORCAL
    ErikNORCAL Veteran Member
    1,173
    14
    Aug 6, 2003
    now in VA
    Looks awesome.
    What wheel and tire combo?
    Alignment specs?
  5. 73Z L92
    73Z L92 Veteran Member
    241
    93
    Jan 25, 2011
    Carlos, MN
    Very nice.
  6. Robert M Mrozek
    124
    20
    Oct 4, 2016
    Front: P245/40R18 (wish i would have gone a bit wider)
    Rear: P275/40R18
    Nitto Nt555 G2 Summer Ultra High Performance Tire
    Wheels: US Mags Rambler, Front: 18x8 with 5x120.65 bolt pattern; Rear:18x9.5 with 5x120.65 bolt pattern
    Alignment Specs as set: LF (-0.3 deg Camber), (+4.7 deg Caster), (+0.12 deg Toe); RF (-0.3 deg Camber), (+5.0 deg Caster), (+0.15 deg Toe); Total Toe = +0.27 deg.
    FS87LT likes this.
  7. biker
    biker Veteran Member
    3,779
    1,779
    Dec 7, 2014
    Beautiful car and great info with the pics and write-up. 2 things: I think u posted the wheel stud bolt pattern instead of the back spacing. Also, can you measure your height from center of wheel to bottom of fender lip? Gives us a better idea of actual suspension height not affected by tire/wheel diameter. Ok... things...how much wider you think u can go with the front wheel/ tire?
  8. Robert M Mrozek
    124
    20
    Oct 4, 2016
    Thanks biker. I corrected the bolt pattern description. I will take a look into the suspension height measurement.
  9. unrestored72Z
    unrestored72Z Veteran Member
    336
    27
    Feb 17, 2000
    Sacramento, CA
    So what is the backspacing?
  10. ErikNORCAL
    1,173
    14
    Aug 6, 2003
    now in VA
    Looking at us-mags website 18x8” is 4.5 and 9” is 5.29.
    nicely done robert, bet it drives as good as it looks.
