1970 Camaro
Discussion in 'Project Progress' started by rickscamaro, Jan 22, 2013.
  1. 79CamaroVERT
    79CamaroVERT Member
    39
    Dec 19, 2005
    Bend, Oregon
    Hey Rick... I'm glad I got to stop by your house and see your work in progress today... You are doing a great job and I know this is going to be one sweet ride when you finish... Keep up the good work... We'll keep in touch.. Ken
  2. rickscamaro
    rickscamaro Member
    39
    May 21, 2012
    Justin, TX
    Hey Ken! Sorry for taking so long to respond. I appreciate the encouragement! How's your Z doing up there in the northwest??
  3. rickscamaro
    rickscamaro Member
    39
    May 21, 2012
    Justin, TX
    Been forever since I've posted anything in here. Been tons of changes since I was last able to spend some real time on the Camaro. I moved from the Austin TX area back up to where I'm from originally, Ft Worth TX area. Summer has been HOT and other projects have discouraged any work on my car but about to get back at it now that things are getting cooler and back to normal.
  4. rickscamaro
    rickscamaro Member
    39
    May 21, 2012
    Justin, TX
    Some pics I took just before the move.
    Fitting up and getting ready to weld in the firewall body mount brace...
    A little protection (POR15) going on before the floor pan and rocker go in permanently...
    Floor pan screwed in place and toe kick cut out...
  5. rickscamaro
    rickscamaro Member
    39
    May 21, 2012
    Justin, TX
    Brace welded in place...
  6. RICARDO1969
    RICARDO1969 Veteran Member Lifetime Gold Member
    2,086
    Oct 14, 2007
    Waukesha WI
    That is a ton of work!
  7. Da-bigguy
    5,829
    1,801
    Jan 19, 2010
    Cypress, TX
    The car is looking great! Amazing work with the jig. It certainly looks like it is helping with keeping things lined up while you remove the rust.
  8. mackthebulldog
    mackthebulldog Veteran Member
    437
    8
    Mar 18, 2011
    IJsselstein, Holland
    Take your time, don't rush it. Family comes first at all time. Great restauration project and I will follow your progress!
    Greetings from Holland!!!
  9. rickscamaro
    rickscamaro Member
    39
    May 21, 2012
    Justin, TX
    Thanks Bigguy!! I'm certainly happy with the jig. Been a big help.
    Thanks! You're right about the family and really enjoying your thread. Looks like you've done a lot of what I'm about to do.
  10. cubangt
    cubangt Veteran Member Lifetime Gold Member
    2,277
    Jul 5, 2010
    Katy, Tx
    Just curious on this portion how you handled it since you had some much rot, it seems you cut out most of the area and then over lapped the top portion? I ask cause IF my 76 is fixable, I to will need to replace the driver side corner and will def be looking for pics on how others did it.
    your doing a great job, and Im also finally getting back into the garage now that the weather has let up a few degrees..
