1970 double hump heads
Discussion in 'Engine Topic' started by 1970 gold, Mar 7, 2010.
  1. 1970 gold
    1970 gold Veteran Member
    874
    178
    Aug 4, 2005
    White, Ga, United States
    Did any of the double hump heads for 1970 have holes for A/C stuff in the front of the heads?
  2. CorkyE
    10,866
    664
    IIRC, if they come on a '70, then yes, the heads should be tapped for accesories.
  3. 1970 gold
    874
    178
    Aug 4, 2005
    I just bought a set of heads 1970 casting number 3932441 with 2.02/1.64 would these be considered double humped heads?
  4. twozs
    twozs Veteran Member
    8,817
    169
    Aug 5, 1999
    hopewell jct ny
    double hump heads have to do with the casting mark on the end of the head as the original "double hump" heads were 2.02 by 1.60 valves also know as fulie heads as used on rochester FI engines. right? *edit* Right. [​IMG]
  5. yblow
    yblow Member
    50
    Feb 21, 2010
    Orcutt, CA
    Thats rite some had the accesery mounts some didnt, if it has that big old banana alternator braket than thats a sure sign. Just look for the double humps like in the pic and then bolt holes in the head to mount stuff too. The one in the pic doesnt have acc mounts.
  6. 1970 gold
    874
    178
    Aug 4, 2005
    I'm looking to keep true to 1970 and I'm wondering is it worth having a set of 3932441 reworked?? I'm looking for 300/325 HP will these heads get me there???
  7. flowjoe
    8,032
    38
    Feb 7, 2006
    SoCal
    Same runner design as the "186" casting double humps for '69/'70 but the "441"s have a much larger combustion chamber @ 76.28cc's (whereas "186"s have 64cc chambers). "441"s were only offered from the factory in 1.94/1.5 valve configuration and only on the 250HP 350CID engines. If yours have been opened up to 2.02 valves then I'd double check that it was done properly.
    Will they get you to 300HP? I don't know for sure but a lot depends upon the other components as I'm sure you already know. Are you sticking with other '70 pieces as well?
  8. 1970 gold
    874
    178
    Aug 4, 2005
    Yes on the other 1970 parts. Stock intake and Qjet 704202.
  9. ZS10
    12,166
    Jan 18, 2003
    BC, Canada
    Even the small valves 1.94/1.5 will support 325hp with a quick bowl blend and clean up. Large valves were 2.02/1.60 but those heads didn't come like that. Might have to use a small dome piston to get the compression up.
    Any real value in these heads is for building a 'year correct' engine, otherwise the big chamber heads aren't worth much at all. Something to consider before putting much $ into them. If they are 1970 car heads, they would have accessory holes, truck heads, maybe not.
    If your intake is a stock iron one, you're going to make it more of a challenge to meet your goal. The alum Z28 intake/Holley would be preferred.
    Personally I'd make it easy and use a vortec, or aluminum heads and just paint them orange.
  10. flowjoe
    8,032
    38
    Feb 7, 2006
    SoCal
    Using factory ratings for comparison, the only differences between the 250HP and the 300HP 350's are the intake/carb (2bbl vs 4 bbl) and combustion chamber size in the heads (76cc vs 64cc - which, of course, influenced compression), everything else is the same (cam, pistons, crank, etc) - use a different piston, as ZS10 suggests, and you might get to your goal.
