1970 Gas Cap
jondebo
162
Hayward, CA
I finally lost my gas cap the other day (left it on the pump). It was almost 5 years so not bad. Anyone know what the measurements are for the short collar and long collar gas caps for a 1970 CA car? It's a stock tank in a CA car that I removed all of the emmissions parts from. The flare on the outer part of the filler neck is approx. 0.75" deep and the inside catch is about 0.25" deep. I had a vented cap on there before. I'm tempted to just buy all of the available factory style caps and see what fits but trying to be "reasonable" with my ex-wife (my camaro) spending.
31,460
Here’s a link which shows what you need for a replacement.
jondebo
162
Hayward, CA
I'm not so concerned with getting a concourse correct gas cap as much as I am with getting one that is functional for my current tank. Specifically, I see that there is a short collar and deep collar gas cap depending on which filler neck the tank has. This is what I'm trying to determine: Do I buy the short collar cap or the long collar cap, also known as deep shank or short shank?
21,779
Not any of my business but that’s a first about an Ex Wife telling you what you can and can’t do. I know what I would tell my Ex. GFY.
jondebo
162
Hayward, CA
I refer to my camaro as my ex-wife. Sexy, expensive, but I never get to take her for a ride. Not that I like referring to my car as a specific gender. I think that's silly, it's an inanimate object. Still, ex-wife seems like a good descriptor of my Camaro.
67johnny
430
vancouver
Dont know how much gas theft you guys see down in CA but... Stant makes a good locking unit and it takes the risk of theft or fuel tampering away instantly!:bowtie:
21,779
I bought a locking gas cap back in the early 80’s from Canadian Tire, works good when I feel like using it.
tom3
14,676
ohio
I'm pretty sure the actual vented cap is a short shank cap. The non-vented cap for the later models with vapor recovery is a long shank. My vented cap barely catches on a later tank.
70 SS/L78
2,967
Rockford, MN
Original 1970 CA emmision cars had a non-vented cap so guessing the CA emmision stuff is no longer in use if you're using a vented cap. In 1971 the Camaro went to a non-vented cap.
These caps aren't assembly line correct but instead the 2nd design GM replacement cap, which is the next best thing. Difference being the later caps have the 2 ears whereas originals had no ears.
Both of these caps are the same thing. These are actually produced by Stant, not GM. Stant produced them for GM.
