1970 headliner
Discussion in 'Interior Restoration' started by Motorhead3, Mar 5, 2018.
  1. Motorhead3
    Motorhead3 New Member
    9
    Feb 1, 2017
    I ‘m getting ready to do quarters on my car. I’ve removed the window, all rear interior trim pieces and I’d like to just lower the rear section of the headliner to keep it away from grinding and welding. I removed the 2 screws on each side holding the metal panels under the sail panels at the rear. It’s tight and doesn’t want to move. It was replaced before I bought the car so it’s not factory. My friend who does upholstery said it’s glued around the edges, heat it a little and be careful pulling it down. No luck. Any suggestions?
  2. 1971CamaroGuy
    3,827
    194
    Oct 31, 2004
    Yeah it's glued in there...all I can say is be careful tugging on it...that material can rip and ruin your day very easily.
  3. 70lt1z28
    4,248
    971
    Oct 3, 1999
    Beavercreek, Ohio, USA
    Got to do the same thing. Will be watching this thread. My headliner is in really good shape and hate to lose it.
    Any tricks to getting the side metal pieces off? There are clips holding them up.
  4. Plater Tom
    Plater Tom Veteran Member
    1,477
    62
    Feb 2, 2003
    Mt Pleasant, Pa. USA
    Try using a scalpel and low heat to lossen the glue. Tom
  5. Motorhead3
    9
    Feb 1, 2017
    I removed most of the quarter now and I think if I"m careful, its far enough from any welding heat. I'm going to use a welding tarp to cover the back window area hole from sparks.
