1970 LT-1 mpg
Discussion in 'Camaro Questions' started by Mrnmrssmith, Apr 9, 2020.
  1. Mrnmrssmith
    Mrnmrssmith Member
    31
    Aug 29, 2013
    Victoria, Canada
    Finally got my car out for a cruise, first for this year. Over the winter I tuned up the motor, re build the 780 Holley, got the timing dialled in. Curious what mpg this car gets,( not that it really matters) I filled up with 94 chevron until nozzle shut off, drove conservatively for 46km/29miles, cruising 50-60 mph with about 5 stop lights. Pulled back into the same chevron and filled up again same way could not put anymore fuel in..it took 3.6 litres/.92 us gallon, which is 31-32 mpg or 7.5l per 100km. I have a 700r4 with 4.10 gears. Anyone else achieve these numbers? I realize it’s high for a 50 yr old performance engine, I would not have believed it without seeing for myself.
    AEGIS43 likes this.
  2. COPO
    18,900
    1,248
    If your worried about gas mileage with these calculations in an old muscle car then it’s time you need to sell it.
    tjdabomb and AEGIS43 like this.
  3. Mrnmrssmith
    Mrnmrssmith Member
    31
    Aug 29, 2013
    Victoria, Canada
    Not worried, as I stated. Just found it abnormal.
  4. wnmech
    wnmech Veteran Member
    1,023
    149
    Jul 20, 2014
    grand prairie tx.
    That’s awesome gas mileage my pure stock 71Z28 RS with the Holly 780 carburetor and a turbo 400 with the 373 gears only gets 10-11 MPG. But like COPO said I’m not worried about gas mileage but was also just curious.
  5. twestrup
    twestrup Veteran Member Lifetime Gold Member
    221
    115
    Aug 22, 2018
    St. George, Utah
    When mine needs gas, I fill it up. Could care less about MPG, just saying. That me.
    tjdabomb likes this.
  6. Mrnmrssmith
    Mrnmrssmith Member
    31
    Aug 29, 2013
    Victoria, Canada
    I hear ya, I’ve never figured out my mileage before. But doing so, does tell a tale of how your motor is running. Looking forward to more cruising this summer, as I haven’t had this car on the highway much.
    AEGIS43 likes this.
  7. tom3
    tom3 Veteran Member
    12,592
    603
    Aug 1, 1999
    ohio
    Best I ever did with my 70 was 25mpg in back to back fillups. That was built for mid range power and fuel economy. Premium fuel only. More of an experiment than anything else but it actually ran pretty darn good too.
    Mrnmrssmith likes this.
  8. McCune
    McCune Veteran Member
    1,172
    242
    Aug 22, 2015
    st.george utah
    In 1985 my 73 Z28 4 speed wit 4:10 gears got 18 MPH on 300 mile hwy drive. Speed limit was 55 and i would push it to 60.
  9. badazz81z28
    18,001
    774
    Alabama
    MPG is such a dynamic thing...I get way better gas mileage in the Dodge Ram than the wife does...A lot of it is how you drive....
    For starters you have a overdrive transmission. If your light on the pedal and mostly cruising, mileage will be better than stop and go and hammering the gas. You could also question with non stock gears and transmission, the Speedo and such is accurate...that could throw your numbers off.
    I agree with the others, on my Camaro I only pay attention to needle when it’s close to empty.
  10. Mrnmrssmith
    Mrnmrssmith Member
    31
    Aug 29, 2013
    Victoria, Canada
    Absolutely, a lot of factors come into play. I went for this drive with that in mind, which I used gps to track miles...again just curiosity. I also made a few minor changes, tuning, speedometer calibrated and added a vacuum gauge inside. The overdrive definitely makes a big difference, along with the vacuum gauge you can monitor what rpm the motor likes, in turn helps with fine tuning=morepower.
    One time deal...I like my highway speeds to be around 75mph so overall mpg not much of a concern
