1970 Lug Nuts
Discussion in 'Original Drivetrain Topic' started by citrusz, May 11, 2016.
  1. CanadianCopper
    CanadianCopper New Member
    16
    Jul 9, 2017
    california
    What size is the correct lug nut for a 1971 Z? Is it 3/4 or 13/16? Thanks, mark
  2. COPO
    20,533
    2,263
    7/16"stud, "tall cap" is .450" from the top of the hex to the end of the cap.
    The nut on the right is 13/16". Not sure what the tall boy is on the left,
    but I would think it would use the same jack wrench/socket.
    Someone else posted this pic in a previous thread.
    CamarosRus likes this.
  3. secondgenaddict
    secondgenaddict Veteran Member
    423
    198
    Dec 29, 2012
    Upstate South Carolina
    I have looked at doing these (including building the progressive deep draw dies) and have done a good bit of research including original drawings -
    FWIW the LAST NOS SET of 20 - traded hands for over $1000. LS6 Chevelles, GSX Buicks, W30 and Hurst Old's tend to run the prices up and drive them out of existence.
    From all my research I can do them in small quantities - 10-20 sets at $400 / set
    HOWEVER if the volume is much larger than that 50-100 sets the dies need to be heavier built for a larger press and probably need to have it done at a larger shop...
    There are a large number of cars which wear these lugnuts... including all open face GM wheels from 1968-1973 - Chevelle SS 69-72, Nova SS 69-72, OLDS SS1's, Olds SSII's, Buick GS/GSX, Camaro N66 69 & Camaro 70-74 Ralley and Z28 wheels, Vega GT, El Camino with open lugs through 73... basically all except pontiac rally II.
    Go to a show and check any of these cars NONE will have their correct lug nuts.
    My question is how many set is a legitimate number to talk about producing?
    They are going to be at least $100 I can tell you that for sure...
  4. 70lt1z28
    4,207
    965
    Oct 3, 1999
    Beavercreek, Ohio, USA
    I've thought about this too and would do it if I wasn't so busy.
    I wasn't thinking of a full on prog die, but more of multiple (3 or 4) individual tools and hand transfer the parts. Maybe laser the blanks rather than build a blank die, although that would be the easiest tool to make.
    Talked this over at some length with Joey Gray (http://joeysmusclecars.com/) and he seems to think folks would pay about 140 to 150 A SET.
    The problem is, there is the repop ones out there that are very close and only the highest level of restoration will pay an extreme difference in cost. How many that is depends on the cost delta. I personally would go for about 200 a set, but never 400. Just too much for this one item, at least at this stage. The LS-6 guys and GSX Buick guys would probably go for more, but then their cars go to 6 figures too.
    Then there is always the risk that you get yours done 5 minutes after the perfect Chinese repop hits the market! Not trying to discourage you, but that's whats gone through my mind.
    Double R Restorations likes this.
  5. Budz
    3,257
    298
    Mar 17, 2002
    Ashburn, Va USA
    FWIW....the market here on NastyZ28 with the Originality guys for our 'Custom Clips and Things' thread only ran in the 30-50 buyer range...not a huge market.
  6. secondgenaddict
    423
    198
    Dec 29, 2012
    Scott Fuller Reproductions (SHELBY PARTS) makes a Stainless capped tall crown 1/2 thread 7/8 lug wrench Lugnut which (other than being larger) is the same EXACT design as the 7/16 thread 3/4" nut size we are looking for. They sell for $400 a set on small runs.
  7. WANNARUN
    WANNARUN Veteran Member
    371
    146
    Jun 4, 2012
    Long Island NY
    A9906286-F68D-46AB-A296-D00483842753.jpeg Original 70 Z28 bright lug nuts.
  8. TommyRS70
    TommyRS70 Veteran Member
    1,359
    204
    Jan 31, 2004
    KY
  9. 1972original
    1972original Member
    96
    Oct 30, 2018
    So tell us about these/
  10. fvdillon
    fvdillon Veteran Member Lifetime Gold Member
    919
    Jul 16, 2000
    Crete,IL
    Nice.... found 14 on Ebay a few yrs ago I bought for $85.00. Still haven't found 6 more for a complete set.Jim
