1970 rs/ss verification
Discussion in '1970 - 1973 Specific' started by smedley, Oct 12, 2020.
  1. smedley
    smedley New Member
    Dec 10, 2018
    Hi Folks,
    I am currently looking at a 1970 rs/ss bigblock 4spd car built in Van Nuys Ca.
    All i can tell from vin and trim tag is it was a v8, cranberry red, and had standard black interior. It does have a 12 bolt. What are the chances of this being a real bigblock 4 spd car?
    How many were built in Ca?
    Probably end up with it anyway for a winter project, but would be nice to know
  2. Gary S
    23,926
    1,513
    A Van Nuys car is difficult to identify because the cowl tag has no information on it about SS or RS. There are no records to show how many SS or RS cars were built in LA. The 12 bolt is a good indicator. Look at the date code on it to see if it fits the build time of the car. If it does, that suggests that it is original to that car. Then, check the code.
    Z28 used either 3.73 or 4.10 12 bolts
    SS396/375 used either 3.55 or 4.10
    SS396/350 used 3.31
    SS350 used either 3.07 or 3.31
    These would be the only 12 bolts installed in 1970 Camaros.
    If it is a SS396, then it would need to have a rear swaybar. That doesn't prove it to be one however as the rear swaybar was optional on any other Camaro. SS396/375 rear ends would be posi.
    Does it have an engine? If so, check what it is. An original engine would have the VIN on it. Same with the 4 speed. For an SS, it should be a Muncie and have the VIN.
    RS is just what it is. It is body trim. If it has the RS front end and it is complete, then you can fairly safely assume it is an original RS.
    2ndGenCrazy likes this.
  3. l16pilot
    2,026
    219
    Dec 13, 2004
    Hurlock, MD, USA
    Welcome to the Forum. Check the fuel line...should be 3/8" and with any luck, there should be a build sheet on top the gas tank...and possibly stuffed into the rear seat cushion. A build sheet will be the proof-positive...if it still exists. There was no breakdown of how many SS-396 cars were built in Van Nuys vs Norwood...only estimates and guesses.
  4. smedley
    smedley New Member
    Dec 10, 2018
    Ok thanks guys, i will check it out a little more this week... No engine in it now but i have a 396 to put in it....I doubt there is a build sheet as interior is out of it now....always wanted a bigblock 4spd 2nd gen. so we will see what happens..
  5. ggtsvnv
    ggtsvnv Veteran Member
    1,278
    102
    Jun 20, 2002
    Fallon, NV
    Check the part numbers on the engine mounts bolted on the crossmember for the subframe. Small block mounts and big block have different part numbers. I don't remember the numbers off hand but it been discussed before here so if you do a search you should find them. It sounds like my car. It's a LA built 70 L34 RS/SS 396, cranberry red, black interior,with the L34 however mine is a turbo 400 car.
    Good luck it sounds like a nice find.
    2ndGenCrazy and smedley like this.
  6. flowjoe
    8,047
    45
    Feb 7, 2006
    SoCal
    I happened to have this at my finger tips...
    Standard SB engine mounts should be 3964890 for LH (or drivers side) and 3930930 for RH (or passenger side). These are the taller ones.
    Z/28 and BB mounts should be 3964886 RH and 3982307 LH which are shorter (for obvious reasons).
  7. COPO
    20,873
    2,465
    I would look for a Norwood car that was shipped to Canada when new cause you can get the RPO paperwork from the GM Vintage Group in Oshawa from my friend George Zapora.
  8. badazz81z28
    20,721
    1,415
    Alabama
    Being an LA car, at the end of the day you need paperwork to prove authenticity to be a high dollar car. The partial vin on the engine and trans will help significantly.
  9. mallard
    mallard Veteran Member
    1,193
    361
    Oct 3, 2013
    SK, Canada
    Exactly how I found out my "stripeless" '74 z28 was originally a striped car. Stripes were removed some time after about 1979 and when I bought it in 1984.
  10. 70 SS/L78
    2,911
    140
    May 5, 2005
    Rockford, MN
    Any news on the car?
    The part numbers on the engine frame mounts will be your best clue to being a big block or small block, along with the 3 letter code on the rear axle. The are several other little things that all add up to help confirm too.
