1970 Sleeper project
Discussion in 'Project Progress' started by Scottyd, May 7, 2018.
  1. Scottyd
    Scottyd Veteran Member
    162
    80
    Nov 28, 2016
    I've put off putting together a build thread for my car for a while now. I've been indecisive on what direction I wanted to go with this car but I'm finally rowing ahead with it.
    Initially I wanted to keep the car stock, it has the numbers matching engine along with a replacement th350. There's not much fun in that for me and these days horsepower is easier to come by so I threw that out the window and decided that i want it to be brutally fast but look stock on the outside... A sleeper.
    These photos are the day I brought it home about a year ago. Its a Texas car and is in really solid shape.
    15134656_1443469232337765_427637501696091835_n.jpg 15135952_1443413992343289_2217687067641071231_n.jpg 15219369_1443413915676630_3757279838584786111_n.jpg IMG_20170814_185247_339~2.jpg
    Engine build:
    The engine is a LSA blown 5.3, rebuilt with gen 4 rods, flat top pistons, ported and polished 862 heads with 2.02/1.55 valves, Elgin 228/230 Cam, 585 lift, Howards valve springs, hardened pushrods, ls7 lifters, Melling oil pump, 210 lb hr injectors, 96mm throttle body, ls9 balancer, trunion upgraded rockers, LS Simple accessory kit, muscle car oil pan, Caddy CTS-V intercooler and blower lid. 3bar map sensor, *edit Ms3 Gold Box, Tuner Studio.. I'm sure there's stuff that I'm forgetting.
    27459611_2123372451014103_8417925378361655786_n.jpg 18485299_2123372414347440_8007637259729795495_n.jpg
    Random Eng build pics:
    26171371_1988992651118751_6220089682695420956_o.jpg 23632237_1935343739816976_8218576432983146778_o.jpg 26195700_2003631186321564_1968399037354218568_n.jpg 26196028_2003631229654893_2270648689192395014_n (1).jpg
    The fueling will be handled by 2 Walbro 450's, 8an fuel line and an Aeromotive regulator.
    7/3-SplitRS and 71RSLS like this.
  2. Scottyd
    162
    80
    Nov 28, 2016
    Trans build:
    2004 4l80e, hardened input shaft, red alto clutches, kolene steels, upgraded/replaced sprags. HD2 kit, Roadrunner billet, 3800 stall.
    29744736_2123453271006021_6590382254007867385_o.jpg 29598301_2128104337207581_7426076594512362276_n.jpg 30227048_2135027996515215_7248701019394146304_n.jpg 31189940_2158645390820142_5230164294053658624_n.jpg 31277666_2158645307486817_5637404069334089728_n.jpg 31225941_2158645454153469_3484912253243752448_n.jpg
    71RSLS likes this.
  3. Scottyd
    162
    80
    Nov 28, 2016
    Rear end:
    Stock width Ford 9" housing, Yukon center section, 4.10 Motive Performance Gears, Yukon Nodular Iron Pro N-Case w/ 5/8" Cap Bolts , Aluminum Daytona Pinion Support, 1350 Billet Steel Yoke, Chrome-Moly Steel Spool, 35 Spline Moser axles, 1/2" Wheel Studs, Timken USA Bearings.
    26734384_2016861788331837_4536104465126279626_n.jpg 26804899_2009712099046806_7865396618161419340_n.jpg
    71RSLS likes this.
  4. Scottyd
    162
    80
    Nov 28, 2016
    I removed the old power train, the engine and accessories are being hidden away in my shop in case I ever decide that they need to go back in... Again it is numbers matching so who knows maybe one day it'll be worthy to go back in..
    31416971_2165101290174552_3762855658735534080_n.jpg 31395848_2165101486841199_7874850707906494464_n.jpg 31389069_2164901140194567_4197166638652456960_n.jpg
  5. Scottyd
    162
    80
    Nov 28, 2016
    Sub-frame removal, It's currently stripped of all components and will be getting blasted this weekend (if all goes as planned!) Bushings will be replaced with solid aluminum and a set of Competition Engineering sub-frame connectors are on the way.
    31543065_2166581336693214_7912693355513905152_n.jpg 31488873_2166581443359870_3411591986065440768_n.jpg
    Box of front end parts eagerly waiting for install after blasting.
    I am on the fence about replacing the front coil springs. I've been researching different brands and I'm not sure if it'll be worth the pricing. I don't really care about lowering it. I just want dependability, the car will likely be outfitted with a set of 90/10 shocks. The old springs are a little crusty but may be fine, maybe a few of y'all can chime in on this?
  6. AllensaurusRex
    AllensaurusRex Veteran Member
    544
    32
    May 22, 2013
    Murfreesboro TN
    I went with a Viking coil over set up and like it thus far. If you are going that route with the engine...I think some nice suspension would be worthwhile... just my 2 cents
    Scottyd likes this.
  7. 71RSLS
    71RSLS Veteran Member
    766
    177
    Dec 5, 2017
    Prairie City, Ia
    Very nice car and nice direction you're going with it. I really like your engine and am jealous of the supercharger and turbo combo. I'm in the middle of fixing up a 71 and putting a 5.3/T10 in it. I wanted to go turbo but the budget is blown already. Haha
    For now I'm going to re bush my leaf springs and run my front coils until I save up for lowering springs. I eventually want to auto cross it. First the car needs to run and drive.
    Scottyd likes this.
  8. Scottyd
    162
    80
    Nov 28, 2016
    Are they the Vikings that use the stock control arms? I've been wondering how those work, it looks like they come with large Torrington bearings and mount using the 5/16 bolts in the lower control arm?
  9. 8pack
    2,964
    313
    Aug 29, 2007
    Western, MA
    Regular Coil springs run $150-$200 for a pair....in the scheme of things pretty cheap upgrade.
    I would do a bunch more research on those bolt in coil over set ups. They definitely work well for some people, but remember when you start adjusting the ride height with them you do start to impact travel etc.
    hubedobeedo and Scottyd like this.
  10. Scottyd
    162
    80
    Nov 28, 2016
    I have owned a couple of these 2nd gens and from what I remember the fronts always rode decent, the backs however did not.
