1970 Z28 oil pan wanted
Discussion in 'Swap Meet Section' started by Vettenick, Jan 1, 2021.
  1. Vettenick
    Vettenick Vettenick
    327
    63
    Jul 17, 2019
    Looking for NOS oil pan. Nice used OK.
  2. ronzz572
    2,366
    193
    Feb 8, 2007
    imperial pa
    Just a FYI here. OEM 70 TO 74 z28 oil pans are the same. The NOS pans are not concourse correct. But will function fine. They are stamped out differently. I don't have any pictures to share. But surely someone else may take it further.
  3. flht99b
    flht99b Veteran Member
    836
    274
    Nov 28, 2014
    Knoxville, TN
    Finding a NOS 70-74 pan will be difficult if not impossible. I recently sold one that was used but 99% perfect to a gentleman overseas. 70-74 had the thin front seal, 75 and later went to the thicker front seal and very small changes to the profile shape. Later versions had more changes in shape and were EPD coated. I have an NOS early thick seal version in bare steel which technically isn't correct for a 70. Bought it several years ago for a small fortune. Both early and later lt-1 oil pans show up on eBay from time to time.
  4. 67johnny
    67johnny Veteran Member
    291
    18
    Apr 14, 2016
    vancouver
    If memory serves me right... the front U that mates to the timing cover was 2 1/4 on the early and 2 3/8 on the late.
    Didnt 69 use the same pan?
    Maybe someone can chime in on this one and confirm.
    I know I have been stung by the 1 piece oil pan gaskets not fitting on the early pans!
    To thick and caused a sealing issue!
    Something about the timing covers related to this issue also I think.
  5. Vettenick
    Vettenick Vettenick
    327
    63
    Jul 17, 2019
    Thanks for the input guys. I guess I'll wait and see what surfaces. You never know.
  6. l16pilot
    2,029
    220
    Dec 13, 2004
    Hurlock, MD, USA
    I have an original 70Z oil pan, but do not have the windage tray, drain plug or studs. When I got it, it had a small crack near the oil drain, (the metal gets really thin in that area due to the deep drawn stamping), so I had it professionally welded and leak tested. Oil drain threads are good. I then restored the pan using PPG DP-40 epoxy primer with single stage urethane "steel" appearing top coat. Would be willing to sell for $400 Paypal F&F plus the ride or pick up in Maryland.
    ronzz572 likes this.
  7. GrimSS396
    GrimSS396 New Member
    14
    Mar 16, 2020
    I have an extra windage tray and I think the studs are with it. Came with a 70 LT1 block I picked up.
  8. Vettenick
    Vettenick Vettenick
    327
    63
    Jul 17, 2019
    Thanks! I couldn't do the pickup. I'm in MN. I have no idea what shipping would be.
  9. l16pilot
    2,029
    220
    Dec 13, 2004
    Hurlock, MD, USA
    If you're interested send me your zip code and I can calculate shipping.
  10. Goat
    1,935
    50
    Jun 7, 2001
    moncure, NC
    You can't go wrong with the "pilot". He knows his stuff and is as honest as the day is long....
    l16pilot likes this.
