1970 Z28 Power brake lines
Discussion in 'Original Drivetrain Topic' started by Kurtz, Jul 11, 2007.
  1. Kurtz
    Kurtz Veteran Member Lifetime Gold Member
    305
    Dec 17, 2004
    Hello All,
    Which one of the vendors sell the most correct brake lines for a '70 with the PB option.
    I'm looking for a complete set, front to rear.
    ie. In-Line Tube, Classic Tube, etc.
    Thanks as always.
  2. White81Z
    White81Z Veteran Member
    1,175
    Nov 17, 2004
    NY
  3. fvdillon
    fvdillon Veteran Member Lifetime Gold Member
    919
    Jul 16, 2000
    Crete,IL
    I used Classic Tube once, their stuff seemed like junk to me, and didn't fit that well either. Next car I used Right Stuff, very good. Jim
  4. flowjoe
    8,047
    45
    Feb 7, 2006
    SoCal
    Hey Rick, that's a neat site. I see that they recommend silicon brake fluid. I had alwasy heard that is was a bad idea to use silicon fluid in an older system not designed for it...what have you heard?
  5. 70 LT1
    70 LT1 Member
    92
    Jan 3, 2002
    Dallas, TX
    When I ordered some parts from In-Line Tube awhile back they told me they OEM for several vendors and that RightStuff is one of them.
    John
  6. l16pilot
    1,979
    190
    Dec 13, 2004
    Hurlock, MD, USA
    Flowjoe: Regarding the silicon DOT5 fluid....I used Dot5 in my '30 coupe using all reman'd components for early to mid-70s GM...10 years and still going strong. No leaks, no weeping, no bad seals....and no corrosion! But, I would only use Dot5 in an older system if all new or reman'd components that come into contact with the fluid are used.
  7. Budz
    3,258
    299
    Mar 17, 2002
    Ashburn, Va USA
    I used In-Line Tube for mine. They fit well and still look good.
    One of the small lines was wrong, and when I called them on it, they sent the correct one right away and told me to just toss the other. Don't bother sending it back.
  8. Kurtz
    305
    Dec 17, 2004
    Budz,
    Do you remember what line was incorrect? Another member had mentioned the same thing to me. I'd like to get it right from the get-go.
  9. JJFarmer
    JJFarmer Veteran Member
    2,447
    Jun 28, 2002
    Lenoir City, TN
    The DOT 5 stuff is good stuff. I used it in my 68 Shelby GT500KR and my 69 428CJ Stang, both heavy front-end cars with 428 FE engines. I tended to abuse them both and never had any fade with the brakes. Another plus is that if you spill any on the paint, it just shines it, unlike the glycol based DOT3 & 4 fluid.
  10. Kurtz
    305
    Dec 17, 2004
    JJ,
    Correct me if I'm wrong, but I didn't think brake fade has any thing to do with the type of fluid you use.
