1970 z28 wheel paint
Discussion in 'Camaro Questions' started by ralph amitrano, Jun 27, 2018.
  1. Green hornet
    Green hornet Veteran Member
    2,028
    479
    Oct 11, 2015
    North Bay, CA
    So here is my attempt to refinish a set of original wheels. I don’t have the equipment or the time to duplicate what secondgenmdnaddic accomplished. His work turned out great. Here are photos and the results of my effort. I sandblasted them to bare metal, primed then painted with OER wheel paint. The don’t have the texture and are a little glossy. I may try and put flat clear on to tone down the gloss.
  2. COPO
    21,353
    2,783
    You can achieve the rough factory texture buy spraying the last coat farther away so the paint is almost dry by the time it hits the rim.
  3. secondgenaddict
    secondgenaddict Veteran Member
    424
    200
    Dec 29, 2012
    Upstate South Carolina
    buy some rustoleum textured paint and hit them with it first... use the charcoal only as the color.
  4. COPO
    21,353
    2,783
    I actually liked the color and texture after sandblasting. it looks more like the orig Z wheels from 70-74.
  5. 450bench
    450bench Veteran Member
    3,529
    260
    Feb 25, 2002
    memphis, tn-shelby
    I know this is an older thread but I just re-painted mine using the OER 89310. Nice paint and covers well but as others said it’s a little light and a bit shiny so I did the last coat from about 3 feet away and it helped a bunch. I did tone it down more with matte clear and they came out really pretty nice. I sprayed the clear from about 3 feet also.
    The matte clear also darkened it just enough.
  6. Chris Greenley
    Chris Greenley New Member
    28
    Dec 15, 2020
    You got any pictures after you applied the oer paint . Im not looking for to light of a gray
  7. Chris Greenley
    28
    Dec 15, 2020
    Any problems putting on the rings i purchased a set of aftermarket rings and says it wont fit pouder coated rims
    And I just purchased some rims and would love to have them powder coated
  8. Gary S
    24,217
    1,693
    They are probably concerned about the clips on the rings chipping the powder coating off. Powder coating is likely thicker than paint and not as durable to handling the clips.
  9. Chris Greenley
    28
    Dec 15, 2020
    Your not gona see where it chips it right Maybe I won't pouder coat that area if it doesn't need it you think thats possible
  10. olstyle
    olstyle Veteran Member Lifetime Gold Member
    8,505
    Jan 27, 2008
    Crestwood IL.
    I powder coated my wheels on my 74, with a matte clear top coat and have no problems with the clips. Powder coating properly done should not chip or crack.
    I used Smoke Gray TGIC S1792045, with a Matte Clear Polyester S5709012 top coat. Pics are at the end of my project thread
    Guys project 74 Z28 | NastyZ28.com starting with post # 6441 on page 645
