Mwilson904
- Nov 6, 2016
- 15
hello, I'm new here, not sure if I should've posted this elsewhere.
I went to look at a "rust free" 1971 mostly disassembled "Z28" in between meetings at work.
It was thought to be a numbers matching car, as mentioned completely taken apart and it would cost me 9k to get it in my garage (including transportation). The seller purchased it that way and doesn't know anything for sure. Story is was 1 owner car, original owner started to restore and is no longer with us.
This is what I saw and need some opinions/help:
No cowel tag at that time, possibly packed away.
Rear passenger quarter was replaced, inner fender was not as not attached to outer under at seam, shell in primer but no interior (boxes) so could see about everything except didn't have keys for trunk.
Everything else showed virtually no signs of rust, surface only in some areas
Subframe was removed intact and rebuilt and had 1" sway bar
Found rear springs, open wrapping in middle, only saw 4 leafs not 5
Block there, no vin present (unless I missed it)
Heads were wrapped, couldn't see
Turbo 400 trans, I didn't check for vin
Several holes at bottom of gas pedal area where hinge would go, possibly.
Doors primed and no tags, but decent shape.
Everything else was either boxed or wrapped.
Here's the $9k questions, would you Gamble and go thru boxes later looking for tag and paperwork hoping it's a Z28? And if it was a clone would that be a deal breaker.
Should I be overly worried about the rear quarter replacement? It seemed to have original pans and all else seemed fine.
I ended up telling him if he can find the cowl tag and/or paperwork I would buy it.
What do you think? Pass if no documentation showing it as a Z?
Thank you for your opinions
Mike
Mike
