1971 Project
Discussion in 'Project Progress' started by 1971BB427, Oct 16, 2009.
  1. 1971BB427JR
    1971BB427JR New Member
    25
    Jan 17, 2010
    Ferndale, WA
    I like the full shot!!!!!
    I'm thinking we need one of the camaro and the Austin together....
  2. 1971BB427
    1971BB427 Veteran Member
    746
    Sep 16, 2009
    Portland, Or.
    You need to come down so we can get an action shot of the two facing off against each other! :)
  3. Yellow Jacket
    Yellow Jacket Veteran Member
    356
    Feb 6, 2010
    Portland, OR
    Hey Val, Any new Additions to the Camaro since I seen you last at PIR?
  4. bad436z28
    bad436z28 Veteran Member Lifetime Gold Member
    706
    Oct 2, 2010
    middleville,michigan
    grey pearl beast.
    wow val thats a sweet ride u got there,also love ur austin gasser,nice intake on there,been thinking of running one of them myself,keep up the good work,u have an amazing car there.
  5. bitchin'71SS
    bitchin'71SS Veteran Member
    397
    Sep 10, 2009
    Poughkeepsie, NY
    coolest car on nasty Z in my opinion. It's going to be tough for me not to clone this thing by the time I'm done with mine:bowtie:
    How do you like the ladder bar setup? been thinking about those lakewoods, do they still allow the rear suspension to travel or is it stiff as a board?
    How did you go about mounting the cowl gauges, those are awesome!
  6. 1971BB427
    746
    Sep 16, 2009
    Portland, Or.
    Sorry, didn't get any notice of your post, so just found it!
    The Lakewoods are a pain in the rear to mount. Very poorly designed for a bolt on setup, and they required a lot of modification to make them fit. Definitely not a bolt on item. They don't make the rear too stiff, but they sure make things hook up better to the road, and eliminate wheel hop!
    I built a frame out of 3/8" rod that mounts to the cowl, under the hood, and extends up above hood height. Then welded mounting bracket plates for each individual gauge pod to bolt to. After that I pinted it with Hammerite silver, and mounted everything. My old hood had vents to mount to and the new cowl hood didn't, so I needed to make something to accomdate the gauges.
    Have at copying! No problem to me! The Camaro is going up for sale soon, so it will be somebody else's to worry about copying! 38 yrs. is long enough to own one car!
