1972 subframe alignment to rear rails
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by Nolancm2001, Feb 2, 2017.
  1. Nolancm2001
    Nolancm2001 New Member
    Sep 19, 2016
    Evansville, IN
    Doing a complete restoration with my son. This includes new rear rails, floors, braces, etc. Car was square with good gaps in panels before we started. Repairs are going well. Did subframe repair and have new rear rail and braces sheetmetal screwed in place. Using the attached picture is says I should be 56 5/8 from alignment hole in rail to center of #2 body mount busing on opposite side. I'm 56 5/8 from alignment hole in rail to an alignment hole in front of #2 mount...not to center of bushing. All other measurents are good. Thoughts? Am I reading this diagrahm correctly?
  2. Green hornet
    Green hornet Veteran Member
    2,017
    470
    Oct 11, 2015
    North Bay, CA
    I would think as long as your square with the measurement you would be ok.
  3. Fbird
    5,521
    1,493
    Feb 12, 2011
    atlanta, ga
    you are reading it as I do??? From CL of body mount to front edge (tangent point) of robot hole-slot in rear frame rail.
  4. Fbird
    5,521
    1,493
    Feb 12, 2011
    atlanta, ga
    work with the 92 15/16 dim to each side.... and the 43 3/4 dims... this should prove your square and correct lentgh... the robot hole may be worng due to being a repop.... BUT.... you have many other places to check with! ;)
  5. Green hornet
    2,017
    470
    Oct 11, 2015
    North Bay, CA
    When I replaced my body mounts I needed to check the frame to body square because of an issue that came up. You can see in the photo the points that I used and what my measurements were after I used a plum bob to transfer the location points to the floor.
  6. Nolancm2001
    Sep 19, 2016
    Evansville, IN
    Thanks for all the information. I know working with after market parts can have some some error in the assembly. Passenger side frame rail should be in with the next week or two. Can get a good square check at that point. THANKS!
  7. Nolancm2001
    Sep 19, 2016
    Evansville, IN
    We all llike buold pics and showing youth grow their skills so here are some pics. Bracing car and getting ready to cut out all the rott... 20160729_115610.jpg 20160908_214629.jpg
  8. Bandit723
    Bandit723 Veteran Member
    3,524
    619
    Oct 1, 2016
    Waupaca WI
    Had a 72 Bird that color.....kinda liked it
  9. Nolancm2001
    Sep 19, 2016
    Evansville, IN
    New floors and body mount repairs
