1973 Camaro LS3/4L80/Vintage air/PTFB
Discussion in 'Camaros for Sale' started by 175rgr, Oct 27, 2020.
  1. 175rgr
    175rgr New Member
    11
    9
    Aug 7, 2020
    Updates:
    new exhaust is in, here are some videos.
    https://photos.app.goo.gl/VDeJD4yavc6bMVWw8
    https://photos.app.goo.gl/UnWA9b8rAiG2LhCC9
    https://photos.app.goo.gl/u1FPYwTTJF7YMraM6
    https://photos.app.goo.gl/XHFKdSst278HoPL16
    https://photos.app.goo.gl/2DpthtbbkrNdXdm5A
    1973 Camaro
    Backstory:
    I picked up this car out of California in 2018 completely restored with the body and paint completed circa 2010. The car had 1500 miles on it since its restoration when I picked it up, it had a 383 stroker and the original TH350 transmission with no heat or A/C. I pulled the 383 and 3 speed, swapped in a brand new LS3 and 4L80e, tore out the original wiring harness and replaced it with an American Autowire harness. During the swap I discovered numerous things that I wouldn't have been happy with putting it back together that way so the car got basically all new interior minus the seats, center console, and headliner. Also threw in a full vintage air setup but ended up ditching all of the factory vents minus the center, installed blank aluminum plates and used vintage airs proline series louvers, also added a vent straight into the gauge cluster. It will handle all the stop and go traffic and heat you can throw at it without overheating, it ran all summer long in El Paso on 105-110 degree days with asphalt temps of 140+ with the A/C on max without an issue, it gets 12-16 mpg around town and 18-22 on the highway at 70-75 all depending on your right foot and speed of course. This is a get in, crank it up, crank the A/C and go car, I'm still toying with the tune a little bit because I just cant leave things alone, otherwise it's basically ready to go. I wouldn't hesitate to drive this thing all the way across the country and back. This isn't a corner cutting junkyard LS swap thrown together for a quick profit on a low budget, but it also isn't a $100,000 sema show build. This car deserves to be driven.
    Engine:
    Blueprint LS3 545hp (30k warranty)
    BTR Stage 2 LS3 Cam
    90mm DBW TB with GM DBW pedal
    1 3/4 Longtubes
    Hooker swap mounts
    Holley accessory drive
    Dual 13 inch SPAL Fans + Aluminum Shroud
    Holley EFI Terminator X MAX
    Fuel System:
    Tanks INC EFI Tank
    455LPH in tank pump
    GM 0-90 ohm sending unit
    Aeromotive FPR firewall mounted.
    All new fuel lines
    Transmission:
    Jakes performance stage 2a 4L80e (Warranty)
    Jakes billet 2500rpm stall converter
    Hooker LS swap crossmember
    B&M Supercooler Transmission Cooler
    Holley Terminator X Max Trans controller
    Suspension:
    PTFB Upper control arms
    PTFB Springs
    PTFB Shocks front and rear
    PTFB Sway bar
    PTFB Rear leaf springs
    PTFB HD Leaf spring plates
    PTFB subframe connectors
    PTFB Solid aluminum body bushings
    Brakes:
    C6 Z06 brakes with all new lines
    Wilwood twin pot master cylinder
    Rear:
    GM 12 bolt with Eaton posi 3.42 gears
    Moser diff cover
    Wheels/Tires:
    Boze ZE forged 18 inch 2 piece wheels
    295/35/18 Rear Continential extreme contact DW
    255/40/18 Front
    Interior:
    New A/C dash pad, upper and lower trim pieces
    New Cluster bezel
    Holley EFI Canbus Gauges
    New ACC carpet with mass backing
    New Ididit column
    Full insulation and sound deadening (Kilmat)
    Kenwood BT728HD Head unit
    Alpine R 6x9 rear speakers
    Kicker 6.5 front speakers
    Monster audio amp trunk mounted
    Misc:
    American autowire classic update harness
    New hood with trackspec louvers
    Trucklite LED headlights
    Subframe is fully powdercoated
    All original body panels minus drivers side door skin
    Raingear hidden windshield wiper system
    Price:
    $51,000
    Reasonable offers welcome.
    Call or Text: nine one two six five 6 four four zero 5
    VIDEO:
    https://photos.app.goo.gl/vW2k6tJDZgF64TKC8
    PHOTOS:
    https://photos.app.goo.gl/z9UVnUZrSFPvTKMa8
  2. mrfleet12
    mrfleet12 Veteran Member
    676
    334
    Aug 8, 2014
    West of Chicago IL
    Dang, looks very similar to the one I just sold and sent back to Arizona. If I had the cash, I'd be all over it.
  3. dave@ztech
    4,457
    995
    Mar 27, 2016
    NY
    Really nice car and very reasonable price, if I had not spend the money I did, I would be money ahead buying yours !!
  4. 175rgr
    175rgr New Member
    11
    9
    Aug 7, 2020
    Thanks for the compliments fellas. It cracks me up people spend 80k on lesser cars over on pro touring and I can't get a single bite out of this one, I guess covid hasnt helped.
  5. rosco72z
    rosco72z Veteran Member
    212
    9
    Jul 7, 2000
    Canada eh
    Awesome car, if you don't mind who supplied the dash pad and the gage panel,
  6. 175rgr
    175rgr New Member
    11
    9
    Aug 7, 2020
  7. rosco72z
    212
    9
    Jul 7, 2000
    Canada eh
    Thanks, you've done so much to that car great work and planning
  8. mallard
    mallard Veteran Member
    930
    246
    Oct 3, 2013
    SK, Canada
    Is the louvered hood a style choice or a heat venting necessity?
  9. 175rgr
    175rgr New Member
    11
    9
    Aug 7, 2020
    All of the above. I do enjoy the looks of the trackspec louvers. It extracts enormous amounts of heat and helps keep pressure buildup under the hood down immensely over 100mph. I mostly see the effects in how quickly the intake air temps drop from off idle at a stoplight. If you are asking weather they are needed to keep the engine at safe operating temp, the answer would be no, but they do help.
  10. badazz81z28
    19,205
    1,086
    Alabama
    I can imagine how great they are at pushing heat out of the engine bay....I would want some too but I would need to figure out a way to keep them weather proof too. I wouldnt want rain or water from washing the car all over the electronics.
