1973 Camaro manual brake problems part 2
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by hoov81, Jun 2, 2016.
  1. hoov81
    hoov81 Veteran Member Lifetime Gold Member
    779
    18
    Oct 31, 2010
    Bristol, WI
    I want to thank everyone for helping me with my manual brake problems from the first thread.
    Keep in mind ALL new brake parts front and rear, New master and proportioning valve. ALL new except for brake lines which bleed great.
    Now I'm on to part 2. I blead the master today and the calipers. The brakes seem to be a little better but not much. But I noticed that if I push the pedal once it stops like crap but if I let off the pedal and push the pedal a second time the brakes work a lot better. Anybody have any ideas on what going on?
    Thanks
    Rich
  2. Z27LS3
    Z27LS3 Veteran Member
    840
    Nov 12, 2007
    Pensacola FL
    what brands are the parts and where did they come from ?
  3. haroldpo6
    haroldpo6 Veteran Member
    325
    May 9, 2015
    PC Fl
    Make sure you have a manual master and not one for a power unit, been there on my 70.
  4. boardog
    boardog Veteran Member
    924
    17
    Dec 8, 2006
    north ga
    I have seen brand new master cylinders bad out of the box. as stated above make sure you have a manual one. sometimes its just a small air bubble that is hard to get out. pressure or vacuum bleed the system. I take it you bench bled the master cylinder. if nothing else works take the master cylinder off and take it apart and make sure a ring has not twisted in the bore. I have seen small metal shavings cause a problem. anything can restrict fluid flow.
