1973 Camaro Z28 Acceleration problems.
Discussion in 'Troubleshooting & Diagnosis' started by Fume, May 11, 2021.
  1. Fume
    Fume New Member
    27
    Jul 4, 2019
    A stock AC Delco.
  2. Fume
    Fume New Member
    27
    Jul 4, 2019
    Before the work. All of a sudden it happened. When I went out for a drive the next day
  3. Fume
    Fume New Member
    27
    Jul 4, 2019
    Wasn’t in storage. I was driving the car almost everyday. I guess it’s time to take the exhaust apart.
  4. Fume
    Fume New Member
    27
    Jul 4, 2019
    Damn, I am suspicious about the exhaust going to take it apart. I’ll probably run straight side pipes.
  5. mallard
    mallard Veteran Member
    1,194
    361
    Oct 3, 2013
    SK, Canada
    I like the idea of dropping the exhaust before the mufflers and take it for a rip and see how it behaves. Now, whether that's logistically possible for you is quite another matter.
  6. TTR230
    TTR230 Veteran Member
    487
    232
    Aug 1, 2020
    Burlington, Ontario
    Don't dismiss it as non-engine problem because it doesn't do anything funny revving it in the driveway, an engine under load will show problems that don't show up in the driveway.
  7. flht99b
    flht99b Veteran Member
    836
    274
    Nov 28, 2014
    Knoxville, TN
    10 psi fuel pressure at idle? Really?
  8. Jodi
    Jodi Veteran Member
    824
    542
    May 22, 2019
    Try to feel the pressure or heat coming out of the end of the exhaust pipe first with your hand.
    There wouldn't be much or none at all if it's clogged.
  9. BillyDean7173
    BillyDean7173 Psychopathy Red
    2,848
    980
    May 21, 2014
    Hutto, TX
    I think this problem would be more likely to cause a stall at idle, but are the intake manifold and exhaust manifold ports clean? No carbon deposits or gasket issues? Assuming you're running factory exhaust and not headers. If you're running headers, intake may still be worth a look. Seen plenty of intakes with tons of carbon buildup something fierce. Have a couple 73-74 Z28 ones for sale, too (shameless plug, lol).
  10. rocket dawg
    rocket dawg Veteran Member
    449
    56
    May 5, 2015
    Grand Rapids Mi
    Mechanical advance in the distributor check out okay?
