1973 Camaro Z28 Acceleration problems.
Discussion in 'Troubleshooting & Diagnosis' started by Fume, May 11, 2021.
  1. Postmech
    Postmech Member
    49
    24
    Aug 14, 2016
    Alabama
    What Biker said.
  2. 3PedalJones
    3PedalJones New Member
    8
    Nov 9, 2020
    West Palm Beach, FL
    Check the impedance of your coil and look for any cracks in the insulators on both the coil and distributor cap. I found the replacement coil on my '72 was incorrect - a 3.0 Ohm instead of a 1.5 Ohm, and once I replaced it the same kind of misfiring in that RPM range I had went away. Another idea is to check everything out at night in the dark - see if you have any visible arcing between wires or around the distributor cap and coil insulators.
  3. T/A Tom
    T/A Tom Member
    86
    37
    Apr 29, 2019
    Have you checked the ignition coil? Not exactly sure what you mean when you say it “sounds like a Harley” at times. This could be so many things. How old are the rubber fuel lines? They can collapse at higher RPM and cause the car to kind of “lay down”. So many possibilities here...
  4. T/A Tom
    T/A Tom Member
    86
    37
    Apr 29, 2019
    Yeah, 10 psi is pretty high...
    STUCKINCALI likes this.
  5. Bentley
    Bentley Veteran Member
    120
    59
    Aug 14, 2020
    I would still replace your fuel filter. Fuel volume would be my concern..
    Have you had the carburetor apart?? Possible plugged passages or gunk in the float bowls.. I have had this happen in my Carbureted cars I have in recent years.. Its that wonderful fuel we have now.....
    I saw this happen a few times years ago.. Some exhausts had a pipe within a pipe.. The inside pipe collapses and plugs up the exhaust with no way to tell from the outside... Drop your exhausts at the exhaust manifolds and see how it runs then....
  6. STUCKINCALI
    STUCKINCALI New Member
    25
    10
    Apr 18, 2020
    Ca
    10 psi at idle, what carb are you running? are you running a regulator on it as well? Holley likes 6psi, Edelbrock likes 5.5/6psi max. The other points brought up being springs in your timing advance, or timing (base, full and any vacuum advance needs to be vetted before diving into anything too spectacular. Has it always run this way or just suddenly? Acute issues as mentioned are likely the culprit... more info on the motor and car... exhaust size? muffler types? solid or hyd cam? roller? so many things to consider... I''m going with something ignition/timing-related. What ignition box/distributor are you running? Carbon arcing under the cap? bad rotor? coil voltage? ballast resistor? the list is staggering.
  7. nuhmizer
    nuhmizer Veteran Member
    618
    May 18, 2006
    San Diego, CA
    That happened to me and I found that my distributor was bad. When I took it out it was gummed up and didn't turn freely
  8. Gerald Reyenga
    Gerald Reyenga New Member
    May 10, 2018
    Based on the checks and symptom, I suggest the problem is not ignition but in the carb. If you have Holley 4150 I would pull both metering blocks and check all four main jets for plugging. Reset the flow levels when you re assemble. You are probably running lean in the flat spot from a partially plugged jet.
  9. PbFlinger
    PbFlinger New Member
    8
    9
    Apr 26, 2020
    Hoosierbilly
    Many years ago, I had a similar problem with a 1973 Olds Cutlass. I pulled my hair out over this for weeks. Replaced the entire ignition system, New fuel pump, new carb, new exhaust. In my case it turned out to be that the sock on the fuel pick up inside the tank was degraded. It had a nylon looking mesh sock on it, and something had caused the material to swell up, closing the mesh to where it would barely pass any fuel. Confusing thing was, that pulling the fuel line off of the carb, and putting a line into a bucket, that seemed to pass great gouts of fuel. On the suggestion of a knowledgeable friend, I dropped the tank and found a sock in that condition. Being poor at the time, I just sawed it off and it ran like a raped ape. Well, more like a bored tortoise. It was a stock 73 350 Cutlass after all. But it was back to normal anyway.
    Bentley likes this.
  10. STUCKINCALI
    25
    10
    Apr 18, 2020
    Ca
    So... is this flat spot only between 2,500-3,500 and then you have power again after 3,500 or is it just dead after 3,500? Are you running a vacuum secondary carb or mechanical? Make? Model? Help us sort this out for ya...
