Manofsteele
I need to replace my front driver side turn signal bulb. Does the bulb come out the front or do I have to take it out from the back. What steps do I need to take. All replies very appreciated.
That is the correct way to do it. Push the bulb in and twist.bones57 thanks for getting back to me on this. It is the front turn signal bulb. When you say lens that is what you take off the front to get to the bulb, correct. So, once you do that does the bulb twist to the left and them pull out? If that is the case that is what I am trying to do but the blub will not turn it may be rusted in there because it has been years since it was last changed.
Thanks
