1973 tilt column questions
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by Lynd McCormick, Apr 5, 2018.
  1. Lynd McCormick
    Lynd McCormick Member
    87
    Oct 6, 2017
    Finleyville, PA
    My steering wheel is upside down, so does does anyone know:
    * can I unbolt the shaft at the rag joint and rotate it 180?
    * if I rotate at the joint, do I have to swap the bolts in the rag joint?
    * will the 2 halves of the DD joint easily come apart so I can flip it 180?
    * could I just disconnect the column and pull it in to separate the DD joint?
    * how far up in the outer DD shaft is the inner shaft?
    I have a similar question posted elsewhere but it's lost in the conversation. Sorry if considered a duplicate.
