1973 z 28 rear sway bars bushing parts #
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by cisco 1, Jun 26, 2019.
  1. cisco 1
    cisco 1 Member
    36
    10
    Apr 14, 2019
    quebec,canada
    i have 73 z 28 and looking for back sway bars bushing part # . i like to have those in energy suspension but there web site is not user friendly . sway bars and drag link hare powder coat already
    can i have some input on persons how did find poly or rober bushing for stock sway bars .
  2. Gary S
    24,235
    1,699
    I have the part numbers for 70Z28 which are likely the same as 73Z28. The lower bushing on the spring mount is 480913, and the one that attaches the sway bar to the support arm is 3983072. Those numbers aren't likely to help you as the makers of poly bushings rarely use the factory numbers to identify their replacements.
    The rear swaybar should be 11/16" diameter. You can check that using your open end wrenches to see which one fits the bar. That number should help you get new bushings that fit the bar. Rubber bushings are soft so you can usually use one that is "just close" in size and compress it a bit. With urethane, you want an exact fit or you won't get it back together.
    Try using the exact measurement of the diameter of your bar and see which manufacturer can give you the right bushings.
    cisco 1 likes this.
  3. BillyDean7173
    BillyDean7173 Psychopathy Red
    3,182
    1,198
    May 21, 2014
    Hutto, TX
    The upper drop down link bushing on my 73Z is 3859145. The number is molded into the rubber. It has the metal inner sleeve.
    cisco 1 likes this.
  4. TommyRS70
    TommyRS70 Veteran Member
    1,431
    254
    Jan 31, 2004
    KY
    I still have 11/16 exact fit/ exact rubber composition reproduction lower drop link bushings still available if needed. $35 shipped.
    cisco 1 likes this.
  5. COPO
    21,380
    2,795
    Last 2 pics were from Tommy. The 1st pic is Tommy's bushing that fit like a glove in my 70 Z28.
    cisco 1 and TommyRS70 like this.
  6. TommyRS70
    1,431
    254
    Jan 31, 2004
    KY
    Thanks for the thumbs up, COPO!
  7. cisco 1
    cisco 1 Member
    36
    10
    Apr 14, 2019
    quebec,canada
    Good info
