1973 Z28 Doesn't have fire.
Discussion in 'Troubleshooting & Diagnosis' started by Jhboy10, Nov 19, 2014.
  1. Jhboy10
    Jhboy10 New Member
    16
    Nov 19, 2014
    Rabun County,GA
    Im trying to get a 1973 Z28 up and going again and it seems to not have spark. I have been told the motor is a 1968 350. Cleaned points and distributor cap and plugs. Turns over doesn't hit once. Set the points to 15/1000s and try again, nothing. Take out a plug and ground it to block, then turn it over and there is no spark. Finally took off coil and tested it in an ignition simulator and it works. Haven't been back to the car yet. Any tips??
  2. ls777z
    ls777z Veteran Member
    2,209
    34
    Feb 19, 2000
    Clay,NY
    Have you checked the coil and spark plug wires? If coil is good something is going on between there and the plugs. Battery fully charged up as well? Low voltage from there will affect spark.
  3. COPO
    21,095
    2,616
    Change the condenser. I've seen new ones that were dead.
  4. azkeebler
    azkeebler Veteran Member
    584
    Dec 14, 2011
    Manteca, ca.
    You may need the yellow wire that usually runs from the "R" terminal of the starter to the + side of the coil to supply 12 volts for starting.
    Also, make sure you have the coil connected correctly, - to distributor, + 1 wire to ignition switch and to 1 wire to "R" terminal of starter.
    I assume you know that you check and adjust the point gap with the distributor bumped to the open position. (Some that are new to points ignition don't know,& hard to see/tell with the dizzy in the back of the motor)
  5. Jhboy10
    Jhboy10 New Member
    16
    Nov 19, 2014
    Rabun County,GA
    Thanks im gonna go back and try different coil and plug wires, and ill check for the yellow wire. Also something I forgot to mention is that the car was stolen from the previous owner and the switch wont turn it over someone put a push button in the dash.
  6. ls777z
    2,209
    34
    Feb 19, 2000
    Clay,NY
    Time to wire it like it should be otherwise you might be continuously chasing electrical gremlins. :(
  7. stevenp3762
    stevenp3762 BANNED
    1,466
    Feb 7, 2013
    bradenton fl.
    Check the rotor cap too.
  8. 71flh
    71flh Veteran Member
    1,001
    29
    Jun 1, 2010
    DFW
    So much changing of parts. So little measuring.
    One problem. Many plug wires. Change plug wires?
  9. Jhboy10
    Jhboy10 New Member
    16
    Nov 19, 2014
    Rabun County,GA
    Tried again today and no luck. Test light to coil its getting power. Cleaned points again. Adjusted points. Cleaned inside of distributor cap. Tested condenser it works. Put on good coil wire and plug wire, grounded plug to block still no spark. Unless the points are no good what else is there to check?
  10. stevenp3762
    stevenp3762 BANNED
    1,466
    Feb 7, 2013
    bradenton fl.
    rotor.
