1974 Muncie M21
Discussion in 'VIN, Trim Tag & Drivetrain Decoding' started by RLP, May 18, 2020.
  1. CamaroNmotion
    CamaroNmotion Veteran Member
    391
    42
    Jan 8, 2006
    Buffalo, NY
    There were NO muncie transmissions of any type built in 1974. Production ended in 1973 and the transmissions were saved for Vette's, Z28's and TransAms. Switch to Borg Warner was stated in a GM letter in Jan 74, however there were Muncie's left over and used up till late Feb or early March 1974. My original 74 Z28 02B came with M20 muncie. Something I noticed from your photo stamping has the vin and date code stamped together on one side of the transmission, mine has vin one side and date code on other side. And whats with the xxxxxxx, never saw that. Your transmission is a re-stamp...and a bad one at that.
    Ricks72Z28 and Z28PILOT like this.
  2. RLP
    RLP New Member
    16
    May 18, 2020
  3. RLP
    RLP New Member
    16
    May 18, 2020
    I posted this on another forum and amazingly a guy posted pics of his 74 z/28 M21 with xxxxx on his also. His M21 was dated the day after mine. P4R24B. He says these were late installs and restamped. His was an 03C car vin# 197xxx later than mine. His vin/date code were also on same side. Maybe yours was opposite because you have an M20?
  4. RLP
    RLP New Member
    16
    May 18, 2020
    I thank everyone who responded to this thread. I will be selling this 74 z/28 M21 in the near future after I pull it from the current vehicle and will share the link here if anyone is interested. I wanted to get the correct info and try and find out if this z/28 is still running the roads and offer current owner the M21.
  5. RLP
    RLP New Member
    16
    May 18, 2020
  6. Jonesy
    Jonesy Veteran Member
    518
    49
    Jun 7, 2008
    Minnesota
    I already answered this in another forum he posted in.
    Its not a restamp. My original 33,000 mile 74 z/28's M21 was built a day after this one. It is also XXXX'd out like his. My car was built 03C with M21 trans.
    4N179503 is my VIN. It was stamped 3 times on this case. This transmission is definately the original one to my car
    Heres a pic of my trans stamping. These M21's must have been laying around and were used up as needed.
    [email protected] and Cardinal like this.
  7. Jonesy
    518
    49
    Jun 7, 2008
    Minnesota
    To clarify, I said the M21 was used after Jan 74 and that the XXXX were the way the factory deleted a mistake stamping. Heres more pics of my tranny shows 73 date marks on components. 3925661 case, 3978764 tail shaft, 335308 side cover. Has TCS switch and Stewart Warner speedo reducer. You can see a big ink 3 on top of the case in black ink. Also has a W ink stamping on it.
  8. Jonesy
    518
    49
    Jun 7, 2008
    Minnesota
  9. Jonesy
    518
    49
    Jun 7, 2008
    Minnesota
  10. BigBlock73
    2,173
    93
    Jul 10, 2002
    Accord,New York
    Might be 72 strike leftovers
    My 73 had a 307 that was restamped at the factory
