1976 Chevy Camaro - (Aurora Colorado)
Discussion in 'Camaros for Sale' started by dr350jja, Nov 4, 2017.
  1. dr350jja
    dr350jja New Member
    19
    Jul 10, 2013
    Aurora, Colorado
    SOLD
    ****1976 Camaro. This car was a project of swapping in a reconditioned 350 V-8, that was never completed. Still have a set of good tires for it. Car has an automatic transmission. It is in non-running condition, since the engine swap has not yet been completed. Needs to have the carb and ignition parts installed.
    Parts that have been replaced:
    Reconditioned Chevy 350 V-8
    Edelbrock 600 CFM Performer Series 1405 Performance Carb
    Edelbrock Chevy SB aluminum intake
    Fuel pump
    Water pump
    Chrome timing cover
    Chrome valve covers
    Steel oil pan
    MSD electronic distributor
    MSD ignition coil
    MSD ignition control unit
    Spark plugs & wire set
    Engine oil pump & shaft
    Exhaust headers
    Cherry bomb mufflers
    Engine mount brackets
    Engine harmonic balancer
    Engine flex plate
    Drive belts
    Upper & Lower Radiator hoses
    Heater hoses
    Alternator
    Battery tray
    Starter
    Chrome alternator brackets
    Oil pressure switch
    Coolant thermostat
    PCV valve
    Steering linkage, tie rods, center link, & idler arm
    P/S pressure hose
    P/S return hose
    P/S pump & pulley
    Upper & lower control arm bushings
    Upper & lower ball joints
    Sway bar bushings & links
    Front coil springs
    Washer pump
    Front brake calipers
    Rear brakes & wheel cylinders
    Brake master cylinder
    A/Trans filter kit
    Transmission mount
