1977 Z28
Discussion in '1977 Z28' started by rich m, Sep 3, 2003.
Thread Status:
Not open for further replies.
  1. 77Z28BLACK
    77Z28BLACK Veteran Member
    162
    Nov 25, 2008
    Montreal, Canada
    how strange part Z and part LT... why would GM put them together ??
  2. 77 rs
    77 rs Veteran Member
    305
    Sep 11, 2011
    cape may county, n.j.
    Please note my post #1891. On 12/13/76, a new option "sport model option" is added rpo z28- not a model and not Z28. So, an LT could in theory have option # z28. Don't know exactly when Z-28 came about as a seperate model. Will check a few GM books in a few days for any other info.
  3. MadMike
    MadMike Administrator Staff Member
    13,620
    74
    Feb 11, 1999
    Dawsonville Georgia
    They did in 1973 & 74. Maximizing the dollars. The Type LT is a high dollar car and the Z28 option piles a bunch of profit on top of that...
    I wasn't aware you could combine these in 1977. I don't believe you could I'll need to check. But as far as the window crank blanks.... that's probably what they had, so they used them. Why (re)design and produce a button when you don't need to. Slap them "Type LT" buttons in.
    >No where in the order guide I see that you can order the LT in a 1FQ87,
    The Type LT is a specific model (1FS87). Z28 was just an option.
  4. COPO
    18,795
    1,199
    Huh, NOT so.
    I have the 1977 Chev Camaro Order Sheets here and Z28 is not a RPO option.
    The Models you could order were, 1FQ37, 1FS87 (LT) and 1FQ87/Z28
  5. 77Z28BLACK
    162
    Nov 25, 2008
    Montreal, Canada
    Here's one posting as a 77 Z28 LT showing VIN 1FQ87L with those same "Type LT" buttons..... http://77z28camaro.blogspot.com/
    correction, it's the same car..... lol
  6. 77 rs
    305
    Sep 11, 2011
    COPO- I have the revised option list 12/13/76. It lists 2 new options on the rpo list 1st option is close ratio 4 speed. only other new option is 'sport model option" rpo z28. All options are listed. Next update is april '77. Z-28 is seperate model. By the way , has anyone ever seen the dealer-added electric drivers-side mirror?
  7. MadMike
    13,620
    74
    Feb 11, 1999
    Dawsonville Georgia
    I have the order guide. Nowhere on the guide when you're ordering a Type LT do you have the option of applying Z28.
    Where you can order the Z28 - you're ordering a 1FQ87 model.
    My theory on the window buttons is - just because they say "Type LT" doesn't make the whole car a Type LT. Rather than spending $5,000,000 making some "CAMARO" buttons - just slap the Type LT buttons in there. "nobody will know the difference".
    I also noticed there's 4 distinct interior levels. 2 standard and 2 custom. a couple of the custom cloth (or all of them?) are reserved for the Type LT. But you could override that if you knew what you were doing.
    I think some of this confusion is... apparently Z28 isn't an RPO per se. You can't order it. To get it, you need to order 1FQ87/Z28 - which is still a 1FQ87 (base camaro).
    So it's not really a distinct model, nor is it an RPO... but an ordering process technicality.
  8. 77 rs
    305
    Sep 11, 2011
    MadMike- Do you have the 12/13/76 revised option list with these 2 new options?
  9. COPO
    18,795
    1,199
    My order pages are from January 10, 1977. Mike's correct. The only thing on that car that's LT is the window crank hole covers.
  10. 77 rs
    305
    Sep 11, 2011
    COPO- Maybe between 12/13/76 and 1/10/ '77 rpo z28 became Z-28. Now, I wonder if any rpo "close-ratio 4 speeds were installed in ANY camaros between 12/13/76 and 1/10/77 as this is listed as a seperate rpo.
Thread Status:
