1978 Trans Am 10 bolt posi questions
Discussion in 'Transmission & Driveline Topics' started by Gasoholic, Feb 8, 2020.
  1. Scaleytail
    Scaleytail Veteran Member
    150
    30
    Jun 12, 2016
    North Aurora, il
    Had a 2.73 rear end in a 350 auto 78 Camaro. Added the Edelbrock Performer Intake and Cam plus Herman headers and buried the 130 mph needle on the highway. Miss my youth except for the fact I had no brains.
    jeff swisher likes this.
  2. 351maverick
    351maverick full time Ebay seller/hustler/car killer
    3,851
    559
    Aug 11, 2010
    erie, PA
    825 for that junk ratio rear axle is a JOKE
    seller obviously is a clown
  3. Burd
    702
    135
    Oct 6, 2011
    Just off Woodward
    Gasoholic likes this.
  4. Gary S
    23,814
    1,459
    Years ago I was looking for a Trans Am posi rear end for my Son's Z28. I found over a dozen of them in the local wrecking yards here, but every one of them was either a 2.41 or a 2.56. He wanted a 3.42. It took a couple of years of looking, but finally I found a 3.42 posi in a junked Z28 for him. It seems that almost all the Trans Ams with automatic trannys got the 2.41 or 2.56 as the Pontiac engines were good engines for torque, but lacked rpm capability. I never did find a Trans Am in my local junkyards with a 4 speed manual that would have had the better ratios.
    A couple of years later there was a rummage sale near my house. The guy had a 3.23 posi from a T/A that he would sell cheap, but by then, we didn't need it.
  5. HOGDADDY
    HOGDADDY Veteran Member
    469
    27
    Jun 8, 2005
    Birmingham,Alabama
    I scored a 3:42 limited slip (posi) from a Trans Am in the late 80's from a salvage yard. The salvage yard told me it wasn't a posi and the price was $100.
    It was a posi : ).
  6. BCB57
    BCB57 New Member
    May 16, 2017
  7. Plant Engineer
    Plant Engineer Veteran Member
    413
    128
    May 17, 2017
    Fort Mill SC
    I had a 77 T/A that initially had a 400 in it. I blew the engine up when I was 15 and my dad and I went to the junk yard and bought a SD 455 for $400. Those were the days. Threw a different intake on it and an 850 Double Pumper and did a re ring on the engine and a new cam . Threw it in the T/A with its 2.73 gears and I could boil the uniroyal tires off all day long and go 165 MPH. Thanks Dad. Sold the car a few years later for $900 after my '69 Camaro got driveable. Ah, the early 80's.
  8. BCB57
    BCB57 New Member
    May 16, 2017
    I have a 10 bolt posi from a '71 with 4.11 gears in great shape. I would make you a great deal on it but I think the cost of shipping from Houston to MI would be prohibitive....
  9. 70RamAirIII
    70RamAirIII Pontiac-aholic
    74
    21
    Jan 10, 2005
    Calgary, Alberta
    if my memory serves me, the 403 powered TA's had a 2.73, while the 400 powered TA's had a 3.23 (or maybe in 1978 auto dictated 2.73's!?);
    If it is from a TA, it should be a posi - as this feature came standard with the TA.
    Since the ratio is just that, a ratio, you could have a friend (or maybe the seller) help you guess where about the ratio is;
    have one of the axles slowly turned one full rotation, and count the number of full rotations on the pinion side;
    not quite three rotations of the pinion would be a 2.73;
    nearly three and a half pinion rotations would be 3.23;
    You could also have an aftermarket ring and pinion in there, and hit the jackpot.
  10. Plant Engineer
    413
    128
    May 17, 2017
    Fort Mill SC
    2.73 in in the 400's unless it was the W72 6.6 .
