1978 Z28 Build
Discussion in 'Project Progress' started by Carter, Mar 1, 2017.
  1. Carter
    Carter New Member
    11
    Apr 6, 2015
    Calgary, AB
    It all started with a 78 that sat in a field for the last decade.
    Automatic trans, 350, black interior, "yellow" exterior, beaten to hell (Mostly on the passenger size)
    First impressions were not great. But I bought it anyways!
  2. Carter
    Carter New Member
    11
    Apr 6, 2015
    Calgary, AB
    Started to tear into it. Its all down hill from here!
    Nests in the engine bay!
    Pulled the seats, the carpet was.....busy
    Found an unfired bullet (under the carpet was nasty!)
    Then, I pulled the carpet...
    The rust goes up most of the firewall.
    Rear passenger floor pan.
    Drivers side floor pan
    Both torque blocks are rusted through.
    Cleaned up some rust, trying to maintain a sense of humor!
    Not pictured is the rusted trunk, quarters, fenders, doors and cracked bumpers. At least its trying to pay for itself!
  3. Carter
    Carter New Member
    11
    Apr 6, 2015
    Calgary, AB
    Forgot to mention the car needs both full rocker panels replaced...
    At least it runs and drives right??
    Right??
    So, basically every panel needs to be replaced/fixed.
    Many said I should scrap it...but i'm pretty stubborn. One day on Facebook I found a suitable donor, bought it the very next day.
    Overall a solid car, some surface rust, typical rust on rockers, rear valance, and toe panels. Manual trans body with all the linkage, no trans and a knocking 350.
    Some kids went to town on it with rocks. Smashed all the windows and turns parts of it into a golf ball.
    But, id rather fix dents than rust any day.
    Pic from the add cause I forgot to take a pic from the back.
    Both fenders look the same.
    Both rockers are the same.
    Dents
    Roof seems okay, outside of a few dents.
    The only real bad part, drivers side sub frame is toast. But the sub frame on the "yellow" car is good.
  4. blackbomb
    blackbomb Veteran Member Lifetime Gold Member
    142
    Oct 11, 2010
    East TN
    Looks like your making some progress hopefully you found the worst of it now.
    I remember when I started tearing mine apart and jus kept finding rot... Seems like everybody that looked at it said I was crazy for putting any money in it then u get the typical stare when u say it's a 79... Like wow this dude's crazy lol.
    Good luck keep trucking along and forget the nay sayers
  5. 78Z28rocker
    78Z28rocker Member
    34
    May 8, 2006
    Auburn,AL
    Keep plugging away! You'll get there before you know it.
  6. COPO
    18,796
    1,200
    Keep on it. Here's a pic of mine I ordered new in '77 when they 1st came out. 4-spd blk/blk.
    Pic is from 1978.
  7. Zspoiler
    Zspoiler Veteran Member
    3,497
    290
    May 6, 2012
    Federal Way, Washington
    That going to take a lot of work.time and cash.I hope you are up to it. Good luck to you.
  8. Carter
    Carter New Member
    11
    Apr 6, 2015
    Calgary, AB
    Started to dig into it a bit last weekend.
    Removed the seats, carpet and interior panels.
    Found some (thankfully inactive) residents
  9. Carter
    Carter New Member
    11
    Apr 6, 2015
    Calgary, AB
    Update from the weekend.
  10. Carter
    Carter New Member
    11
    Apr 6, 2015
    Calgary, AB
    Few more
    Bit more back here than I expected.
