1978 Z28 Engine Code
Gary S
24,986
I have my copy of the Camaro White Book here, and it does not specify which codes go with which transmission. It simply lists the engine codes by engine size, so it won't help us here.
WS6
495
Lake Superior-Michigan USA
I looked in my GM parts catalog and it does not give the trans with the suffix codes, just engine codes by model and option code. Then you have to use a chart on next page to see what trans were available by model and within the model by engine.
MadMike
13,633
Dawsonville Georgia
The GM master code book provided to me by Alan Colvin lists:
CHS
76 350, 165 net hp, LM1, 4bbl, A/T, Fed - full size
Since the engine in question is matched with the 4 speed which also matches the car they're installed in - I'd say in his case, CHS is correct for this particular car. But it's not typical.
TheFastForester
1,598
Berthoud, Colorado
Hmmm.....I'm doing some other research as well. Here's a response to my individual request from an ebay seller that has the following ad out for bid right now on a 1978 Z28 4 speed:
"Hello, the engine suffix code is on the build sheet and it is CHS and the transmission code on the sheet is ZU. This is the original to the car born with drivetrain." Ad link: http://cgi.ebay.com/ebaymotors/ws/e...00276778311&ssPageName=ADME:X:RTQ:MOTORS:1123
And this is a Van Nuys car too...so apparently if the CHS code for '78 Z28's with the Borg Warner T-10 manual tranny was a "non-normative practice" they were stamping it from Ohio to California!
I've got some other feelers out to a couple other auctions on ebay for apparent original, 4-speed 78 Z's. I'll let you know what I find.
Thanks again for all the info on this!
TheFastForester
1,598
Berthoud, Colorado
Heard back from another of the ebayers selling a 1978 Z28, original manual transmission car. Here is there response to my question on what the engine coding was:
"Hi,
Thank you for your interest in the 1978 Camaro Z28. I have the codes from the engine block from this unique car.
Casting on left rear of block—3970010
Date Code , right rear of block –E 16 8---May 16 ,1978
Right front of block----VO517CHS
18L608766----Which matches last 8 of the cars’s VIN #-1Q87L8L608766
Thank you
Greg Chismar
Sales Manager
Best of Show Automotive L.L.C.
5782 Heisley Rd.
Mentor, Ohio 44060
Cell:(440) 251-1457
Ph: (440) 350-1480
Fax: (440) 350-1638
Email: [email protected]
www.bestofshowautomotive.com"
Here is the link to the car sale on ebay:
http://cgi.ebay.com/ebaymotors/ws/e...Categories&_fvi=1&item=280284289945&viewitem=
Another CHS engine code for an original m/t car, not an automatic tranny as the websites state.
WS6
495
No matter the final car assembly plant, the engine come from only one plant in Flint (code V) and that's where the V0517CHS was stamped. The assembly plant stamped the CON VIN 18L608766.
TheFastForester
1,598
Berthoud, Colorado
Here's another response from an ebay seller, auction ended tonight for a 1978 Z28, original drivetrain car:
"Keith,
After a lot of fun trying to get the code, I have it! There is a code, with additional numbers stamped slightly over it.
V0424CHS with the following stamped partially over it, 3438"
If you check the auction site out at http://cgi.ebay.com/ebaymotors/ws/e...10322027941&ssPageName=ADME:B:WNA:MOTORS:1123 you'll see the 3438 is the last 4 numbers of the VIN of the car. Another CHS code for a manual transmission car! I wonder what some of the automatic tranny Z28's were coded as in 1978, maybe it would be good to cross-reference with some of those.
