1979 camaro oil type
Discussion in '1978 - 1981 Specific' started by miastewie, Sep 9, 2021.
  1. CorkyE
    11,393
    915
    For a stock 305, WalMart 10w30 or 10w40. I've ran it in some of my older vehicles, it meets all manufacturers specifications, never had an oil related issue. No need to waste money on the high dollar oils.
    MChamp likes this.
  2. Zspoiler
    Zspoiler Veteran Member
    4,079
    467
    May 6, 2012
    Federal Way, Washington
    back in the day 10-40 w or 10-30w is what usually came in those engines depending on the time year .with a 1/2 quart filter .I prefer a 1 quart filters myself usually Frams
  3. tom3
    tom3 Veteran Member
    13,692
    1,232
    Aug 1, 1999
    ohio
    After reading and researching all over on this deal, I just gave up and bought a three jug case of the Lucas 10-w40 Hot Rod oil on Amazon. Seems like nobody can agree on anything when it comes to oil for the older motors, and the oil companies won't give straight answers. "Meets or exceeds" don't mean a thing on this deal.
    RTSE and xten like this.
  4. MChamp
    MChamp Veteran Member
    292
    76
    Jun 6, 2021
    north carolina
    yeah tom, agreed, it's all opinion. I like Lucas products, the trans. stop-leak saved my butt in the mountains drivin' a subaru. I guess the bottom line is to change it like you're s'posed too. \m/
  5. 1959Buick
    1959Buick New Member
    13
    Oct 1, 2019
    Mobil1 10W-40 and a Napa Gold/Wix filter.. I have 360000 miles on my engine
  6. DennisG
    DennisG Member
    70
    27
    Dec 26, 2016
    To reduce camshaft wear, flat tappet engines require an oil with about 1500 ppm zddp, more than is commonly available in oils presently produced. The anti-wear compound, Zddp, content has been greatly reduced since 1994 as it damages catalytic converters.
    (zddp is zinc dialkyldithiophosphate)
    (ppm is parts per million)
  7. COPO
    21,091
    2,614
    If Mobil 1 has no ZDDP, then don’t use it or your cam will go south.
  8. DennisG
    DennisG Member
    70
    27
    Dec 26, 2016
  9. tom3
    tom3 Veteran Member
    13,692
    1,232
    Aug 1, 1999
    ohio
    But we need to consider the engine setup and mileage. Old old motor with sagging valve springs and well worn in parts would probably be ok with used french fry oil. I can remember tearing down old small blocks with lifter bottoms you could drink coffee out of, lifter valley was full of sludge, and the motor ran fine. A fresh build with a modern cam grind and all new machine work would really need that barrier lubrication to survive I think.
    MChamp likes this.
  10. MChamp
    292
    76
    Jun 6, 2021
    north carolina
    yeah, to zinc or not to zinc, being the question. always been my teaching during break in it's a must. especially with flat tappets. change it afterwards to whatever temperatue recommendations are and just keep it fresh. I've poked holes in the return passages, changed the oil and kept on..
    DennisG likes this.
