1979 z vacuum issue
Discussion in '1978 - 1981 Specific' started by rodebcada, Apr 22, 2020.
  1. rodebcada
    rodebcada 79zrod
    28
    Aug 25, 2013
    nc
    Just had the engine bay detailed and painted. Now the ac/heat controls wont work. Thinking its a vacuum issue. Anyone have a pic of hoses that should hook to the vacuum ball and does the vac ball play a role in the transmission modulator. Trans started to shift hard. Never had any issues before. Only has 7400 miles
    Thanks
  2. Gary S
    23,086
    1,088
    The vacuum ball doesn't affect the transmission modulator. The modulator has its own line off the intake or back of the carb and directly down to the tranny. It is commonly pulled loose when messing with the engine. Start there by looking at that line.
  3. Zspoiler
    Zspoiler Veteran Member
    3,533
    299
    May 6, 2012
    Federal Way, Washington
    I would also buy an assembly manual for you car .They are around $25.00 .It might help you with any other issues down the road ,Good luck to you.
  4. rchydzik
    863
    25
    Nov 13, 1999
    Colbert, WA USA
    Behind the carburetor there is a vacuum tee in the intake runner. The hardline goes to the transmission vacuum modulator and the rubber line goes to the ball on the HVAC box. If both are not connected, you will have the problems you describe.
  5. Twisted_Metal
    27,660
    1,288
    There's also a little vacuum line (which looks like a heavy wire) running from the vacuum ball through the firewall a few inches to the passenger side of the distributor.
    That's the source of vacuum for all of the various HVAC actuators.
  6. rodebcada
    rodebcada 79zrod
    28
    Aug 25, 2013
    nc
    Bingo! Cracked hose at the vacuum tee and the small line to the vacuum ball had fallen down in behind everything else. Hooked lines back up and rough idle, transmission hard shift and hvac issues gone. Thanks guys. Best 2nd gen site out there.
    hossz28 likes this.
