1979 Z28 Engine Lift Brackets
Discussion in 'Original Drivetrain Topic' started by toones, Oct 13, 2020.
  1. toones
    toones Member
    47
    Feb 15, 2015
    San Diego, CA
    I am trying to find the correct engine lift brackets for a 1979 Z28 350. I have looked through search results, the assembly manual, and the illustrated parts guide but cannot find any part numbers or pictures.
    Classic Industries and Camaro Central show different images for the 79 and Ebay is all over the place as usual.
    Does anyone have a picture or can confirm which brackets on a website are factory correct for a 79 Z28?
  2. Jonesy
    Jonesy Veteran Member
    517
    49
    Jun 7, 2008
    Minnesota
    Here my drivers side front one. It is mounted using 2 bolts.
  3. Zspoiler
    Zspoiler Veteran Member
    3,934
    415
    May 6, 2012
    Federal Way, Washington
    Look at an assembly manual .It should have the part numbers as well.
  4. toones
    toones Member
    47
    Feb 15, 2015
    San Diego, CA
    Unfortunately, the assembly manual does not have the part numbers.
  5. toones
    toones Member
    47
    Feb 15, 2015
    San Diego, CA
    Thank you. That is very helpful. Do you have a picture of the rear (right rear) one?
  6. Jonesy
    517
    49
    Jun 7, 2008
    Minnesota
    I'll see if I can take one here in the next day or two.
  7. Jonesy
    517
    49
    Jun 7, 2008
    Minnesota
    Here you go!! Hard to get at that back one.
    Rear One
    Front one
  8. Jonesy
    517
    49
    Jun 7, 2008
    Minnesota
