1980 Z28 suspension advice
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by KGKZ28, Feb 6, 2019.
  1. KGKZ28
    KGKZ28 New Member
    14
    Jul 2, 2012
    Hershey, PA
    Looking on any advice for 1980 Z28 suspension. The car is not taken out outside Sunday drive and some fun runs around town. I will be letting my son drive the car and want to make sure it is safe. The current suspension is original, and hardware is all present. If I am going to replace all the front / rear shocks and bushings would it make sense to upgrade components? If so what items and any suggestion on a cost effective system that does not need to be track ready just normal driving and a little back road fun.
    Thank you
  2. Coadster32
    2,170
    307
    Oct 2, 2013
    Milford,CT
    I redid the suspension on my 79 a couple of years back. Seeing as how it was a fair weather, street driven car for me, I went and replaced all the bushings with OEM rubber stuff. All the upgrades would have cost alot of money, and on the roadways here in CT...not worth the money. My guess is that you'll here different, and for different reasoning. My car rode way better than it ever had, simply because the old bushings were shot. All the money that you can save not buying tubular a-arms, 4-links, etc...you can get the better shocks, sway bars, and frame extenders, and still be way ahead of the game. I agree about already having it apart...I went through the same thing. Best of luck no matter which way you go. Hope your son enjoys the car.
  3. KGKZ28
    KGKZ28 New Member
    14
    Jul 2, 2012
    Hershey, PA
    Thank you
    Thank you for the help
  4. KGKZ28
    KGKZ28 New Member
    14
    Jul 2, 2012
    Hershey, PA
    Any thoughts on OEM rubber or using Polyurethane benefits
  5. CorkyE
    11,215
    836
    OEM rubber will work great for your intended use. I went with all Moog steering and suspension parts, got the best deal from Rock Auto. I've never considered poly as a viable option. There are two kinds of poly users; those that squeak, and those that will squeak. Good luck to you and your son on this project.
    John Mangan likes this.
  6. Lowend
    16,108
    1,085
    Mar 25, 1999
    San Jose, CA, USA
    +1 to above. Rubber and Moog replacement parts may be the best way to go here.
    I really like Bilstien shocks for applications like this. Stay away from KYB shocks They are cheap, and are completely valved wrong for our cars.
    Do plan on replacing the subframe bushings with solids. The job is a PITA, but is critical to making the car behave well. There is a great walk thru on this here
  7. nova75mike
    nova75mike Veteran Member
    387
    8
    Mar 20, 2008
    Etters, PA
    adding my .02 for the stock style rubber bushings. used poly in the past...never again. all I heard was SQUEEK!!!! annoying to say the least. Got my MOOG rubber bushings and all ball joints, tie rods, etc. from Summit Racing, and +1 for the Bilstien shocks.
  8. Zspoiler
    Zspoiler Veteran Member
    3,917
    412
    May 6, 2012
    Federal Way, Washington
    A lot depends on your budget also ,You can add a little at a time, Rebuild the front suspension using a lot Moog parts .And rubber body bushings There are shocks by KYB,Koni ,Carrea ,etc, ,You can go with a stock replacement springs or a little stiffer aftermarket springs. You can use your stock sway bars and or go to a larger size. I use a 1 1/4 front bar and a 7/8 `s rear bar .I use a grease-able polyurethane sway bar bushings .There are all sorts ways to do so .Just do your research and its up to you to decide .Good luck to you,
  9. rchydzik
    897
    39
    Nov 13, 1999
    Colbert, WA USA
    Good shocks are the best bang for your buck. The Z28 is a pretty good car to start with. Agree with everyone, bushings, maybe subframe connectors, but good shocks (i like Koni) will be best money spent. The only place for polyurethane is the swaybars.
  10. budro6968
    budro6968 Veteran Member
    3,837
    722
    Apr 2, 2016
    Jax Florida
    If your main suspension like ball joints,Tie rods center link and idler and the rest are good the simple stabilizer struts are easy and shocks. Grease the heck out of them wipe the the goo. Also grease the front wheel bearings while you are there. As far as body mounts I like the old school rubber. Poly is ok but you might get that squeak after a while. Dry silicone spray helps. Good luck with your project.
