1 more small step.....rear end fully installed, sway bar back in location (13 yr hiatus) fuel tank tested(pump inside) and reinstalled, filled diff 1 bottle slip juice 2 1/2 bottle 75-90. Welded in nuts to floorboard where the sheetmetal screws WERE for the ehaust hangars. Welded up other exhaust hanger holes, still working on e-brake concept. I will probably make a hardened swage tool and swage ball ends on the original BLAZER cable to adapt to the TA front cable connection. I contacted XXXX cable maker...$300 for 2 cables ....uhm...PASS.
